1991 360 into 1971 Demon. Fuel concerns #1337482
11/18/12 10:34 PM
11/18/12 10:34 PM
Sturgis S.D.
tripleblackcuda Offline OP
Sturgis S.D.
I bought a 1971 Demon that someone started putting a 1991 360 out of truck, into the car. My concern is what should I do for a fuel pump and what ways have you guys wired yours?
thanks!
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: tripleblackcuda] #1337483
11/18/12 10:43 PM
11/18/12 10:43 PM
IN
ahy Offline
ahy  Offline
IN
Is it staying EFI or getting converted to carb?
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: ahy] #1337484
11/18/12 10:55 PM
11/18/12 10:55 PM
kentucky
roadrunner7020 Offline
kentucky
If you are going back to carb then you'll need the la style timing cover and a cam snout extension from Hughes to mount the mechanical cam centric. If you're styling efi I'd go with a retrotek pump or something similar. Unless you are looking to make big power then a aero motive pump would be nice. There is a company that makes gas tanks with efi pumps fitted in them for our cars but I can't think of the vendor off hand.
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: roadrunner7020] #1337485
11/18/12 11:18 PM
11/18/12 11:18 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Or if your going carb, then maybe a low pressure electric pump. If you do go electric, theink about adding in an inertia cutoff switch for the pump.
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: roadrunner7020] #1337486
11/19/12 12:15 AM
11/19/12 12:15 AM
X2, then buy a mech pump & your done
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: RapidRobert] #1337487
11/19/12 02:46 AM
11/19/12 02:46 AM
Sturgis S.D.
Sturgis S.D.
I was going carb on this one. My thoughts were an electric pump instead of a mechanical one.
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: tripleblackcuda] #1337488
11/19/12 08:57 AM
11/19/12 08:57 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
there is no 1991 361. 360 yes - 361 no..
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: MoparforLife] #1337489
11/19/12 09:03 AM
11/19/12 09:03 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
did i miss somthing?
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: bonefish] #1337490
11/19/12 06:05 PM
11/19/12 06:05 PM
dogdays Offline
dogdays  Offline
Forget the mechanical pump, keep the modern accessory drive.
Use a Carter P4070 street poump to feed your carb. Mount it back by the tank and out of the airflow from any exhaust tubing in the area.
Mine has worked for decades.
There are times when electrical is better, even for a mechanical type of fellow!
R.
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: dogdays] #1337491
11/19/12 07:12 PM
11/19/12 07:12 PM
IN
ahy Offline
ahy  Offline
IN
R.
Re: 1991 360 into 1971 Demon. Fuel concerns [Re: roadrunner7020] #1337492
11/21/12 02:08 AM
11/21/12 02:08 AM
Sturgis S.D.
Sturgis S.D.
I ordered a kit from Hughes today, we will see how it works.
