Gen3 question 6.1 #1337273
11/18/12 05:48 PM
11/18/12 05:48 PM
Garry Owen Offline OP
Looking for some recommendations on a cam. It's not going to be a track car, but I do want a healthy cam. Where I want to end up is a something that will kill on the street but still have some get up on the highway. I'm a cheap [Edited by Moparts - Family Friendly Site - Keep it clean] so I've layed out some end items to base the cam question and ptv clearance. End product will be an airhammer cai, heartthrob catback, tranzformer, 180 thermostat, udp, and 11.1 compression and a cam with tune. So there's the basic "what cam?" question but also what's the best route with bumping up the compression? Thinner gasket or milling the heads, and the ptv issues that might show up with said cam. Thanks in advance
I asked this on lxforums but wound up getting the basic vendor call me answer. I really want to know what issues I would run into with milling the heads or thinner gasket to increase compression. I don't want to notch the pistons, due to budget. Is this even possible and could there be a cam to run in it?
Re: Gen3 question 6.1 [Re: Garry Owen] #1337274
11/18/12 05:49 PM
11/18/12 05:49 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Maybe ZIPPY will chime in
Re: Gen3 question 6.1 [Re: MattW] #1337275
11/18/12 06:06 PM
11/18/12 06:06 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
HHP offers some BES designed grinds in stage 1,2 and 2r.
Mopar to the bone!!!
Re: Gen3 question 6.1 [Re: 72Swinger] #1337276
11/18/12 06:14 PM
11/18/12 06:14 PM
Guess I should be more specific. With an off the shelf cam and milling/gasket sizing to 11:1 comp, are the valves going to smash into pistons? Or am I into a custom cam that might be a pita to tune. Or is it as easy as custom length pushrods?
Sorry, I havent cracked an engine open in about 10 years. I'm relearning
Re: Gen3 question 6.1 [Re: Garry Owen] #1337277
11/19/12 09:35 PM
11/19/12 09:35 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Call Comp and have them run your combo through there computer. They can tell you if it needs checked.
Re: Gen3 question 6.1 [Re: FastmOp] #1337278
11/20/12 11:39 AM
11/20/12 11:39 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
DO NOT MILL 6.1 HEADS.
You only need to run something about a 219/223. That has taken LX's into the low 11's with heads
The 6.1 doesn't need the higher compression. You can't run bigger than about 223/227 without running into serious piston to valve clearance issues.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen3 question 6.1 [Re: AlexP] #1337279
11/20/12 02:19 PM
11/20/12 02:19 PM
Thanks Alex. So what's the thinnest gasket I can run and still run an off the shelf cam.
Re: Gen3 question 6.1 [Re: Garry Owen] #1337280
11/20/12 04:09 PM
11/20/12 04:09 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I wouldn't worry about swapping gaskets. If you want compression, put a set of stock eagle heads on it. It will accept your stock intake and headers with no issue. That would be a 13:1 E85 sipping monster. Look up Buckeyeguy on lxforums for a guy running our stage 2 eagles on a stock 6.1 shortblock and running 11.70's with a tiny c am.
You could de-shim the stock MLS head gaskets if you really wanted compression, but truthfully with such small cam profiles on an already high CR motor....there is no need.
Plus, hemi's get into weird valve train noise when you change geometry. I wouldn't mess with any of it.
Port the heads, throw a cam in and be done.
Re: Gen3 question 6.1 [Re: AlexP] #1337281
11/20/12 04:32 PM
11/20/12 04:32 PM
I had thought about going the e85 route but being moved around so much it becomes an availability issue. I've been looking at a couple cams and trying to wade through the hype vs. Real word gains. Since I'm moving back to Texas at the end of the month I'll see if I can make a few shop visits.
Re: Gen3 question 6.1 [Re: Garry Owen] #1337282
11/20/12 05:19 PM
11/20/12 05:19 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I can help. I still have a ton of connections in the hemi market.
E85 still isn't readily available enough to daily drive on around here.
Re: Gen3 question 6.1 [Re: AlexP] #1337283
11/20/12 05:51 PM
11/20/12 05:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
When u day not to mill 6.1 heads is it because the decks are to thin? Or does it take away to much piston to valve clearance? Also, why does the Gen III get noisy valve train if you mess with the geometry? Sorry for the rapid fire questions just trying to learn about these engines
Re: Gen3 question 6.1 [Re: WO23Coronet] #1337284
11/20/12 06:00 PM
11/20/12 06:00 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
1. 6.1 heads are expensive and not getting any cheaper. No reason to cut them. There is plenty of room and material to tailor compression in there without cutting the deck.
2. They aren't thin. Only the 5.7 eagle is thin in a few spots, but nothing really critical.
3. Most all hemi cams are ground on a 6.1 base circle. To compensate, a 5.7 block with a 6.1 cam would use 6.1 pushrods as a general rule of thumb to prevent uncessesary lifter movement.
Re: Gen3 question 6.1 [Re: AlexP] #1337285
11/20/12 07:31 PM
11/20/12 07:31 PM
Once I get settled in, I'll get in touch with you. Still trying to dig through the wheat and chaff over on lxforums about the best performing cam.
Re: Gen3 question 6.1 [Re: Garry Owen] #1337286
11/20/12 07:34 PM
11/20/12 07:34 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
All of the vendors are using the same lobes for their cams.
A 214/218 from Inertia, HHP, PWR and any number of others will all make the same HP within 5-10%.
After working for a major Hemi Vendor for years, I can say these facts without a doubt in my mind.
Finding a good tuner is where your time should be spent.
Re: Gen3 question 6.1 [Re: AlexP] #1337287
11/20/12 07:36 PM
11/20/12 07:36 PM
Tracking. I have a few tuners in mind right now.
Re: Gen3 question 6.1 [Re: Garry Owen] #1337288
11/20/12 07:41 PM
11/20/12 07:41 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Jerseyboy, Hemituner and lafrad all come to mind as really good tuners.
Re: Gen3 question 6.1 [Re: AlexP] #1337289
11/20/12 08:30 PM
11/20/12 08:30 PM
Those and I heard Johan is pretty decent.
Re: Gen3 question 6.1 [Re: AlexP] #1337290
11/20/12 11:24 PM
11/20/12 11:24 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Just wanted to say great info - and kudos for helping the OP out...I have been reading the "run around" he was getting on the other forum.
Re: Gen3 question 6.1 [Re: Moparmal] #1337291
11/21/12 12:26 AM
11/21/12 12:26 AM
Well, I guess some message boards aren't for messaging.If I wanted to just call vendors I would have to start with. I was trying to reach out to the end user or someone who had tried something similar. I know there's some good guys over and some that are on both boards, that's why I threw out the question both places. Other than buying parts, I think I'll stick with moparts for answers.
Re: Gen3 question 6.1 [Re: Garry Owen] #1337292
11/22/12 02:27 PM
11/22/12 02:27 PM
Augusta, GA
Lightning Offline
Lightning  Offline
Augusta, GA
I've got a stupid question about the Gen 3's: How come they don't seem to need the bigger duration like the older engine's do?
