Re: Help with 86 Ramcharger Stalling
[Re: jlemon]
#1337261
11/18/12 06:31 PM
11/18/12 06:31 PM
Posts: 684 Maine
jerseybud
Maine
I presume 318 with the fender ESC. Call me ignorant, but I'm pretty sure even the electronic spark control (ESC) engines had a ballast and a ECM. Its got 2 pigtails coming out of the distributor, right? http://ramchargercentral.com/media/?sa=item;in=1061There is a specific way to bypass the ESC computer and detailed in the MP instructions that come with the kit. However, its cheaper to source the parts from a JY rather than buying the kit. The carb on that should be a 2280/6280. Consider the idle solenoid for inspection/broken wires as well as choke function.
[Re: jlemon]
#1337270
11/19/12 02:24 AM
11/19/12 02:24 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I had a 86 Ram/C.Nice truck.It did not have anything on the air cleaner,just the control unit by the battery.Only thing I did to mine was get a carb for a 1969 318.That made a difference.
[Re: Chris2581]
#1337271
11/19/12 04:27 PM
11/19/12 04:27 PM
Posts: 2,058 Seed Corn Capital USA
jlemon
I wasn't sure if it should have had the lean burn but I figured being an 86 it should have an ECU and Ballast resistor but it doesn't. No vacuum advance on the distributor either.
[Re: jlemon]
#1337272
11/19/12 05:50 PM
11/19/12 05:50 PM
Chris2581
Jacksonville, FL
No vac advance or ECU.It's all in the controller by the battery.
