Header, Exhaust, Muffler Recommendation? #1337130
11/18/12 12:15 PM
11/18/12 12:15 PM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
Hi Gentlemen, I will be swapping out my 71 Cuda's exhaust system and want some feedback / recommendation on what I am thinking. This car does not see any track time, but I also do not want to be embarrassed by some Mustang street rat. I am looking for a performance boost and a more aggressive sound. Currently there is no drone while cruising and I want to keep it that way.
3 Questions: Header size? Exhaust size? (going with TTI on both) Which Dynomax Muffler?
440, 0.30 over
452 heads, 3 angle valve job, no porting, stock valvetrain
9.7:1
600 CFM Edelbrock Performer Carb
RPM Performer Dual Plane
SpeedPro Cam #CS-1148 224/224 duration @ .050 lift, 455 int/455 exh, 112 C/L
Factory HP manifolds
Dual 2 ¼ exhaust all the way, Dynomax Ultraflows, H-Pipe, factory 1 ¾” Cuda tips
727 auto trans, TCI Breakaway converter
8 ¾ rear, 355 gears
Thinking of 1 ¾ headers, 2.5 exhaust, 2 ½ Dynomax Ultraflows, X-Pipe, 2 ½ Cuda tips.
Your thoughts?
What about keeping the current exhaust, but going with the headers and swapping the tips to a larger size?
What if I had the Edelbrock Performer RPM Heads? Would that change your recommendation?
Thanks All!
1971 Cuda, 440 custom-build
Re: Header, Exhaust, Muffler Recommendation? [Re: BadFishy] #1337131
11/18/12 12:36 PM
11/18/12 12:36 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
What you have in mind sounds good to me, It's basically what I have
for my Challenger with a 451/Edelbrock heads. That 600 carb is your problem with those
Rustangs.
Re: Header, Exhaust, Muffler Recommendation? [Re: BadFishy] #1337132
11/18/12 02:49 PM
11/18/12 02:49 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Sounds like you have a good plan
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Header, Exhaust, Muffler Recommendation? [Re: BadFishy] #1337133
11/19/12 01:24 AM
11/19/12 01:24 AM
jstforfunn Offline
jstforfunn  Offline
I if it were me I would go to a bigger carb, and Hooker Supercomp coates headers seem to always work best for me.
Re: Header, Exhaust, Muffler Recommendation? [Re: BadFishy] #1337134
11/19/12 04:08 AM
11/19/12 04:08 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would step up to three inch pipes and muffs all the way from the headers, same on the tips I would also look at aquiring a Holley 950 HP, if you want to make sure you can whup up on all the locals rustangs, not the real fast oone though
