Re: Trans fluid in the coolant.
[Re: Big Mopar Jay]
#1336503
11/17/12 01:18 PM
11/17/12 01:18 PM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
sounds like the cooler leaked into the radiator
[Re: Big Mopar Jay]
#1336505
11/17/12 03:55 PM
11/17/12 03:55 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Had a few at the shop that did the same thing.New rad and flush the block.Then drop the pan new filter and fluid.We just started them and let the fluid circulate then changed it again.Never had a problem.Just hope she didnt drive a long way slipping.Worth the 50 or 60 bucks to do the fluid and filter.Rocky
Chrysler Firepower
[Re: SSAAHemiFan]
#1336511
11/19/12 09:17 AM
11/19/12 09:17 AM
therocks
Niles , Ohio
A new trans is worth more than the car.Id use reg ATF to flush.Then refill with the required atf.My brother changed trans fluid in his mini van and used the wrong fluid.I drained it and changed filter and used the right fluid.Its been 4 years and still no problems from it.He drove it for about a week or so with the wrong fluid.Rocky
Chrysler Firepower
