COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 #133585
10/07/08 06:57 PM
10/07/08 06:57 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
CAN ANY ONE GIVE ME SOME FEEDBACK ON THESE I LIKE TO USE THEM ON A 440 OR MABYE SOME BRAND OF ROCKERS
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133586
10/07/08 07:35 PM
10/07/08 07:35 PM
IN
ahy Offline
ahy  Offline
IN
I used them on a 496B with great results (243@.050 fast lift cam with .55" lift).
Geometry was good and I like the durability of steel. The engine was apart after about 500 miles and shafts and rockers looked great. They should be matched up with Comp's shafts of correct hardness.
With really high lifts and spring pressures, galling of the shafts has been reported. The fix is to get bronze bushings installed (RAS - Rocker Arm Services is one company that does this).
In my application they worked great as supplied by Comp.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: ahy] #133587
10/07/08 07:44 PM
10/07/08 07:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A friens had those on his 440 and they started galling of the shaft/rocker. His machinest suggested honing the rockers for a bit more oil clearance or bushing them.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: 451Mopar] #133588
10/07/08 11:04 PM
10/07/08 11:04 PM
Puyallup, WA
LemonWedge Offline
LemonWedge  Offline
Puyallup, WA
Pro-Comp Electronics makes a set that is just like these, but come with bronze bushings, cupped adjuster studs for ball end pushrods that also have oiling galleys machined into them to oil over the top of the arm. Not made by Comp Cams, not made in the USA, but fairly nice stuff. Pro Comp is one off-shore company that is making a name for themselves (have you seen their heads?!)
LemonWedge - Street heavy / Strip ready.
468” Lowdeck MaxWedge - 10.42 @ 128
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: LemonWedge] #133589
10/08/08 05:52 AM
10/08/08 05:52 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Sure are making a name I have 3 broke rockers from one set on a stock 77 2bbl....stick with the comps...
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: quick77rt ] #133590
10/08/08 07:26 AM
10/08/08 07:26 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
yes they sure are making a name , and it's NOT good ...
CCJ
Mainstream Media is the new Pravda
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133591
10/08/08 08:38 AM
10/08/08 08:38 AM
Cedar Lake IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Cedar Lake IN
Are you talking about PN 1321-16 http://store.summitracing.com/partdetail.asp?part=CCA%2D1321%2D16&autoview=sku
I was interested in these as well. Jegs and Summit are both about 9 weeks out on these.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133592
10/08/08 11:48 AM
10/08/08 11:48 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
This is the ones I believe. This is the one I'm running with bronze bushings as I'm running a roller cam.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: cudarex] #133593
10/08/08 12:55 PM
10/08/08 12:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
This is the one I'm running with bronze bushings...
That's the way to do it... having RAS do their bushing mod was a really good idea.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: BradH] #133594
10/09/08 01:15 AM
10/09/08 01:15 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
These have been on my 383 for 3+yrs... Not a problem... Street driven and not EASY miles... Freeway, burnouts, hard miles! You get what you pay for... Comp Mags
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133595
10/14/08 08:08 PM
10/14/08 08:08 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
WELL I GUESS I WONT GET THESE NOW THEY ARE TELLING ME 12/12/08 TILL SHIP OUT THAT 4 TIMES THEY BEEN BACK ORDER SIN AUG.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133596
10/15/08 07:24 AM
10/15/08 07:24 AM
Cedar Lake IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Cedar Lake IN
Seriously? Have you had an order in since August?
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133597
10/15/08 10:56 AM
10/15/08 10:56 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Get ahold of Dwayne Porter a member here. He's a Comp distributor. He may have a inside advantage since he buys direct from them.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133598
10/15/08 12:30 PM
10/15/08 12:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Haven't had any issues with mine running about 500 lbs open spring pressure.
I think many posted instances of galling/metal transfer can be traced to too much spring pressure (I wouldn't run any more than 500 max), overtorqued rocker shafts (better hold downs and studs do not allow more torque, use 25 ft lbs max regardless of the hardware) and wrong assembly lube (use only regular motor oil, or one of the thin assembly lubes like clevite bearing guard....do not use anything thick and pasty).
Rich H.
Esse Quam Videri
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: ZIPPY] #133599
10/15/08 01:35 PM
10/15/08 01:35 PM
Chapel Hill, NC
O
orangecrush Offline
orangecrush  Offline
O
Chapel Hill, NC
I am running about 512lbs. spring pressure and I also had a problem with slight galling of the shafts. After cleaning up the shafts I called RAS and they said to take a dremel or cutoff wheel and cut a couple of 1/4"-3/8" long shallow grooves from the center of the oiling hole on the shaft so that oil will distribute more quickly and evenly across the shaft where the rocker rests on. I did this and it worked great. No more galling.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: orangecrush] #133600
10/15/08 03:19 PM
10/15/08 03:19 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Like this, called banana grooving:
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: GTXKen] #133601
10/15/08 06:31 PM
10/15/08 06:31 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
YES THE END OF AUG. THEY SAID THAT THEY DONT HAVE ANY SHAFTS FOR THE ROCKERS
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: FOXY312] #133602
10/16/08 08:44 AM
10/16/08 08:44 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
You could do like I did and order the rockers from a Comp dealer (Dwayne Porter in my case) and buy the shafts, holdowns and studs from RAS.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: cudarex] #133603
10/16/08 10:50 AM
10/16/08 10:50 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Actually Comp Cams is backordered on 1321, both the shafts and the rockers are out of stock.
Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5 [Re: ZIPPY] #133604
10/16/08 04:41 PM
10/16/08 04:41 PM
i think i might have a couple sets of those on the shelf if you guys need them. i'll take a look tomorrow when i go back to the shop.
