Page 5 of 5 1 2 3 4 5
Re: BES Apache flows! [Re: Guitar Jones] #1335493
11/20/12 05:03 PM
11/20/12 05:03 PM
Nebraska
72Swinger Offline OP
Nebraska
Thats bull about torque. The 6.4 was engineered to produced more torque down low because although its first iteration made like 500hp it didnt feel much stronger than the 6.1. Thats when the variable length runner intake came into play. SO now the 6.4 "feels" stronger in the 4300lb land barges they put them in. Yeah im pretty sure torque was at the top of the list with 6.4, even though the ports dont support that.
Mopar to the bone!!!
Re: BES Apache flows! [Re: 72Swinger] #1335494
11/20/12 05:12 PM
11/20/12 05:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Veriable runner intakes are partially spec'd for the reason above, but it also has to do with cold start issues.
If you've ever had a car with a variable runner intake fail, the car will misfire like crazy.
The drivetrain of these cars is suited perfectly for right about 500hp. After than, it all starts going very quickly. They knew the potential of these combination and I strongly feel that the "weak" drivetrain is more of a fuse. It prevents people from bolting on Forced induction or something similar and making a ton of power without a serious commitment to the rest of the car.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: BES Apache flows! [Re: AlexP] #1335495
11/20/12 08:26 PM
11/20/12 08:26 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Any ideas on ET or 0-60 improvements with the 8-speed going in next year?
Re: BES Apache flows! [Re: SRT6776] #1335496
11/20/12 09:44 PM
11/20/12 09:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Didn't the 8 spd drop the V6 cars 0-60 times by a second? Now I expect the V8 cars won't benefit that much cause the 8 spd is perfect for a low torque peaky (compared to a V8)V6, but I imagine it'll be significant.
Re: BES Apache flows! [Re: AlexP] #1335497
11/20/12 10:19 PM
11/20/12 10:19 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I don't agree with the overall results. IMHO a Apache, ported or not is better suited to a 440 and above.
I've dealt with a racer in direct compeition to Alcharger. He ran less cylinder head (eagle) and was still faster over all and also less CI.
An effcient head is what we build for. Different styles work for different aplications.
A lot of what you're saying makes sense, Alex. You've probably forgotten more than I know about the these new hemis. But I still can't get around this: why would Chrysler spend so much money in R&D to design a new head for the 392 if the older 5.7,6.1 or eagle would have made more power? If it's a low end tq issue, that could have easily been reduced electronically. I can't help but think the engineers wouldn't have done it if the port velocity was that bad. They still did despite the low compression,small cammed,low stalled, and heavy application.
I believe that was infernalAl who did the head swap on his stroker; eagle to apache who picked something like 40 HP to the tires.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: BES Apache flows! [Re: onebaddakota] #1335498
11/20/12 10:23 PM
11/20/12 10:23 PM
Nebraska
Nebraska
Someone really needs to build a 434 or bigger out of a 6.4 and see just what its capable of. If anyone has about 10K burning a hole in their pocket I will take one for the team and graciously volunteer....
Re: BES Apache flows! [Re: 72Swinger] #1335499
11/20/12 11:47 PM
11/20/12 11:47 PM
NY usa
540challenger Offline
NY usa
Well i got the apache heads sitting here besides my big bore alum block but i won't have the funds ready until around this time next year to get the build going
Re: BES Apache flows! [Re: 540challenger] #1335500
12/31/13 04:01 PM
12/31/13 04:01 PM
Nebraska
Nebraska
Well 540
It's officially this time next year lol.
Re: BES Apache flows! [Re: 340RICK] #1335501
12/31/13 04:53 PM
12/31/13 04:53 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Need to get Brett Miller to start working on some 3G stuff instead of that old dinosaur W stuff
So Rick
What did you do for the front of your engine? Did you use a factory timing cover and water pump or did you have to make one from scratch.
What does your car weigh? You run some really good times with yours and it has always impressed me. BUT I and most others that would like one of the new Gen III Hemi's do not have a clue how to get around all of the computer issues and the front timing cover issues.
Old Geezer Racing
Re: BES Apache flows! [Re: SCATPACK 1] #1335502
12/31/13 06:29 PM
12/31/13 06:29 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Just went through this entire thread. Man things have changed!
6.1 is dead. No more blocks
If your looking to go big cid aluminum or 6.4. STEFF is the only one I know that has used a 6.4.
The 6.2 Hell Cat is rumored to be coming out in alumunum. WHYYYYYYYYYYYYY
The 6.4 has a bore of 4.09 some its got something. Plus I THINK they used the 6.4 block with a 6.1 crank to test the supercharged challenger. If a production block survives a 700 hp trashing then I won't need anything stronger. Matt
Forgot the 2014 2500 and 3500 come with the 6.4. Same block and crank.
So with the selling of trucks maybe the block will be more abundant.
Re: BES Apache flows! [Re: MattW] #1335503
12/31/13 07:12 PM
12/31/13 07:12 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What heads do the 6.4 truck engines come with? Eagle heads (smaller port better torque) or do they still have the Apache's? Or an all new casting?
Re: BES Apache flows! [Re: WO23Coronet] #1335504
12/31/13 07:22 PM
12/31/13 07:22 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'm thinking the same thing the 5.7 casting. IMO Apache is too big too expensive. But you know how they are!
Re: BES Apache flows! [Re: MattW] #1335505
12/31/13 09:18 PM
12/31/13 09:18 PM
Nebraska
Nebraska
Heres where I am, a year later. This is a 6.1 soon to be 420".
Re: BES Apache flows! [Re: SCATPACK 1] #1335506
12/31/13 09:56 PM
12/31/13 09:56 PM
ohio
all spooled up Offline
ohio
So Rick
RICK has a custom motor plate, stock factory timing cover, bb chevy eltric water pump, and a alt hung on the motor plate................. and I think it weighs 3200 pounds with him in it
