Re: BES Apache flows!
[Re: pittsburghracer]
#1335434
11/15/12 10:05 PM
11/15/12 10:05 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
There is no doubt with those numbers, 390 CFM at .600 lift, that you could not make a very streetable combo run low 9's at 408 CID
#1335436
11/15/12 11:31 PM
11/15/12 11:31 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
I am just questioning durability of said engine when it is raced weekly. Not 3-4 HEMI or Mopar shows a year. Can the last for 3 or 4 years like the "old school" stuff can without blowing the bottom out of them.
They have another beefier engine on the way as well, 6.2L Supercharged Hemi (called HellCat)..that'll be the block you'll want, although the 6.4L Apache block hasn't exactly been tested yet, so it shouldn't be written off.
[Re: 72Swinger]
#1335439
11/16/12 01:26 AM
11/16/12 01:26 AM
Posts: 9,719 Home
SRT6776
Home
there is a bunch of LS heads that claim to go over 400 so I'm not really to impressed by a piece of paper that says a hemi head flowing worse than a LS head
With factory castings?
LPE CNC L92 LS3 Flow Specs Intake valve lift / Exhaust valve lift .200 - 158 cfm / .200 - 116 cfm .300 - 230 cfm / .300 - 161 cfm .400 - 282 cfm / .400 - 201 cfm .450 - 302 cfm / .450 - 213 cfm .500 - 322 cfm / .500 - 220 cfm .550 - 340 cfm / .550 - 226 cfm .600 - 350 cfm / .600 - 231 cfm .650 - 358 cfm / .650 - 234 cfm .700 - 344 cfm / .700 - 237 cfm
IIRC the Apache and LSA numbers are the same or very close.
[Re: 72Swinger]
#1335440
11/16/12 01:27 AM
11/16/12 01:27 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I'm also super impressed with the flow values and potential of the Gen3 Hemi. I think this will be the next big step for Mopar. Just because you can go to Walmart and by some cheap Chinese valve covers doesn't impress me performance wise, i.e. Brand X.... ![](/ubbthreads/images/graemlins/whistling.gif)
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: 72Swinger]
#1335441
11/16/12 01:29 AM
11/16/12 01:29 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
no, but what does that matter? they are available.
oh, we should be happy mopar made a head with huge ports but blow up over 7000rpm?
more insulting is the fact that a guy takes a junkyard 5.3, throws a turbo on it and makes 900-1100hp with junkyard motor. can't do that with a hemi
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 72Swinger]
#1335443
11/16/12 01:38 AM
11/16/12 01:38 AM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Why can't one thread be posted without having more than three replies and it turning into a pissing match. Nothing ever really good comes from it or gets resolved.
I thinks it's great. BES is pretty good at what they do, and winning the engine masters with a gen three hemi shows they know what it takes to make power.
I think the ls is a great engine but mopar people should be excited that we have some new technology that shows promise.
The apache head has been approved for stock and super stock as well.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: gregsdart]
#1335445
11/16/12 10:14 AM
11/16/12 10:14 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Heads are cheap
http://www.mopar.com/part/RL086555AA?s=335847&i=1979575&b=dodge
Short block
http://www.mopar.com/part/RL086564AB?s=335847&i=1979588&b=dodge
I dont know why anyone would even bother with an LA based SB or even a big block when these will put down numbers like that.
Maybe because some conventional LA based small blocks can make 1000+ N/A with a cast intake and sinlge 4.
.....and some conventional big block heads go to 1250+, N/A.
Those are some nice heads BES does, but lets elevate them to "top-o-the-heap" status. They obviously make a real nice street and mid level race deal.
Very true, but $ for $, I would think those heads and a good race shortblock would come in cheaper than either.
yeah, you're comparing some ported, but pretty much off the shelf production heads that are $1100/pr according to the above link to some max effort W7/8/9 heads, or some max effort indy 572's or B1-MC's, etc...
[Re: patrick]
#1335446
11/16/12 10:33 AM
11/16/12 10:33 AM
sixpackgut
Charleston
72SWINGER, what block would you bolt these heads to?
[Re: sixpackgut]
#1335447
11/16/12 10:48 AM
11/16/12 10:48 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Probably the one they were bolted to if I ever score a 392 out of a junkyard. There are plenty of things that disappoint me about Mopar halfassing certain things on their current engineering. Like the crank issue? That definitely blows, but who wouldn't build a stroker anyway? Why can't they build aluminum block Gen III hemis and put them in SRT cars from the factory? But Chevy does. Why did Chrysler cast crossbolted Hemi blocks all those years but couldn't cast crossbolted 440 blocks? Yeah us grassroots guys have been getting screwed since 1964!
Mopar to the bone!!!
[Re: AlexP]
#1335448
11/16/12 11:02 AM
11/16/12 11:02 AM
Posts: 1,784 PA
W5DART66
PA
They're at about 350 @ .550 OOTB.
Good numbers. The trick is to get within 10cfm peak but annihilate it from .0 to .300 lift. Get the air moving quicker earlier.
Big peaks don't impress me on flow sheets or dynos.
There are very few modern hemi shortblocks which can even imagine using that much air effectively.
Why do you think good flow from .000 to .300 lift is good?
[Re: 72Swinger]
#1335449
11/16/12 12:56 PM
11/16/12 12:56 PM
Posts: 2,826 NY usa
540challenger
NY usa
Just to touch up on some stuff.
There is a lot of guys starting to run 6.4 apache heads on 5.7 blocks I am not 100% but i think once you bore the 5.7 block you don't need to notch the cylinders.
On the Factory Alum block issue i would love a factory alum block "cheaper"
However even the Gm guys don't like running the factory alum LS block around 550-600hp mark they switch to the iron block becused it is stronger.
Last thing you got a 392 out a junkyard iam jealous
Keep posting you build please i love more info when you can
[Re: SRT6776]
#1335451
11/16/12 01:40 PM
11/16/12 01:40 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I'm hoping that the 6.2 IS a stronger version of the 6.4 which is a stronger version of the 6.1.
It would be nice to have a block you can overbore for the same price as the 6.1. ![](/ubbthreads/images/graemlins/shruggy.gif)
