Page 3 of 3 1 2 3
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334756
11/21/12 02:48 AM
11/21/12 02:48 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Have them measure the compression distance when they pull the head.
Re: Buying a rebuilt engine that has never been run [Re: BSB67] #1334757
11/21/12 02:57 AM
11/21/12 02:57 AM
moparmedic Offline OP
They are going to check everything including rechecking the ballancing that was done.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334758
11/21/12 08:16 AM
11/21/12 08:16 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Good. But you need to get the compression distance now before the engine is disassembled so you can estimate what you have in compression ratio, and will be able to start making good informed decisions now regarding what you might want/need to do. If you are looking to make this a high performance engine, you need this piece of information before you spend money on anything else.
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334759
11/21/12 10:29 AM
11/21/12 10:29 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Good luck sounds like you will do OK!
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334760
12/14/12 01:28 AM
12/14/12 01:28 AM
I finally heard back from the machine shop. All the machine work that was done is good. The bore, balance, hone, all that. They recommend decking the block and surfacing the heads and redoing the valve job. The pistons are good quality but the rings are low bid. The machinist said they used mismatched main and rod bearings as if they just used left over parts from other jobs.
Basically this engine was a good start and could have been run as is.
I got it for $800 so I think I got a good deal. Just have to tweek it a bit now.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334761
12/14/12 09:34 AM
12/14/12 09:34 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Good news!
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334762
12/14/12 10:20 AM
12/14/12 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes you did...
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334763
12/14/12 04:43 PM
12/14/12 04:43 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I've heard of engine builders using bearing halves from different sets to tweak the final clearances. I'm not saying it's right or what I'd do, just putting it out there.
Congrat's on a good deal otherwise.
Re: Buying a rebuilt engine that has never been run [Re: Dean_Kuzluzski] #1334764
12/14/12 09:40 PM
12/14/12 09:40 PM
Yeah, not sure about that either. The guys at the machine shop didn't mention that as a possibility but could be. Just showed me the ones they took out and there were 3 different brands and one that wasn't marked and was a different color than the rest. Kind of weird.
Should get it back next week and get my tranny from Passon Performance in a couple weeks and be close to driving my Challenger. Just in time for winter...
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334765
12/16/12 01:59 PM
12/16/12 01:59 PM
Central TX
roe Offline
roe  Offline
Central TX
I'm glad it seems to all be working out for you
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Buying a rebuilt engine that has never been run [Re: Dean_Kuzluzski] #1334766
12/16/12 02:46 PM
12/16/12 02:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Right, but not from different manufacturers.
Re: Buying a rebuilt engine that has never been run [Re: moparmedic] #1334767
12/16/12 02:53 PM
12/16/12 02:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Did you get the compression distance or compression height of the pistons from the machine shop?, or piston manufacturer and part number?
Re: Buying a rebuilt engine that has never been run [Re: BSB67] #1334768
12/16/12 09:31 PM
12/16/12 09:31 PM
I didn't. I am just doing a street engine, not going to go really wild with it. Just cleaning up a few things that the machine shop recommended and put it together and run it.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Page 3 of 3 1 2 3
