long wheel studs for front drum brakes???? #1334007
11/11/12 08:39 PM
11/11/12 08:39 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
67 b body, who makes long front studs for drums??
Thanks!
Re: long wheel studs for drum brakes???? [Re: Blown61] #1334008
11/11/12 10:10 PM
11/11/12 10:10 PM
my own world
theraif Offline
theraif  Offline
my own world
i moroso for out 67 dart
Re: long wheel studs for drum brakes???? [Re: Blown61] #1334009
11/11/12 10:19 PM
11/11/12 10:19 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If it is for the stock axle you need to know the stud knurl diameter, then order from Jegs Summit or your local parts house.
Re: long wheel studs for drum brakes???? [Re: rowin4] #1334010
11/11/12 11:03 PM
11/11/12 11:03 PM
IN
ahy Offline
ahy  Offline
IN
If its stock or stock style, the MP/Mancini 3" replacements fit and work fine. That's what I am running.
Re: long wheel studs for drum brakes???? [Re: ahy] #1334011
11/12/12 12:58 AM
11/12/12 12:58 AM
fullmetaljacket Offline
Same here on the Moroso's with the right stud knurl. I made my set-up to be where the drum now serves independently. In other words, iut comes off the spindle on its own as it no longer is glued together with those stud locks.
Re: long wheel studs for drum brakes???? [Re: fullmetaljacket] #1334012
11/12/12 04:47 PM
11/12/12 04:47 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I've got these off my 67 from when I switched to disc brakes I'll make you a deal on. already done.
Russ
