rhs pushrod pinch porting
#1333753
11/11/12 06:10 AM
11/11/12 06:10 AM
Posts: 248 Sweden
Tobbe
Sweden
have a set of rhs magnum heads the have been ported now the shortblock is going to be upgrade to 408cui should i try to go max area around the pushrod area or should i leave it ... the engine have a procharger p-1sc that should have problem feed 400+cui what about sleeving the pushrodhole ,and what about the big "bump" should I try to remove the bolt bump in the channel pics
Re: rhs pushrod pinch porting
[Re: Tobbe]
#1333754
11/11/12 07:46 AM
11/11/12 07:46 AM
Posts: 2,128 sweden
sshemi
sweden
I dont know what "bump" you mean but if you mean the one for the valvecover bolts then yes remove them. Sleeving is a very good idea. I did mine the same id as la heads witch is 1/2" but you can only fit 5/16" pushrods after that.
If you mean the bump for the rocker studs then you dont need to remove them.
I have a pair ported for sale to save you some work. Flowes 298 cfm @ 0.512
Aldough they are the La style
[Re: Crizila]
#1333756
11/11/12 01:46 PM
11/11/12 01:46 PM
Posts: 7,506 Az
Crizila
Az
Intake port pinch area prior to final rework and opening up.
Fastest 300
[Re: Crizila]
#1333760
11/11/12 04:45 PM
11/11/12 04:45 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Available at my local ace hardware. http://www.ksmetals.com/
[Re: Winchester 73]
#1333765
11/13/12 04:54 AM
11/13/12 04:54 AM
Posts: 248 Sweden
Tobbe
Sweden
if you have the old la rockersystem i would say ..yes offset rockers would be an option the later magnum have the "chevy" style rockers...
