Dropping the oil pan on a 440 B body
#1333166
11/10/12 12:22 PM
11/10/12 12:22 PM
Posts: 35 NY
70CoronetRT
NY
I had a series of mishaps to make up for my previous perfect record in life. Anyways the fuel pump rod is now laying in the oil pan of my car. To add insult to injury, the magnet from my magnetic pickup tool is also somewhere in the bottom end.
I know that in my youf, I've done this job about 3 times (dropping the oil pan while still in the car), but I really don't want to do it and I'm ascared about if it can be successfully done with out the rear main seal and the timing chain cover leaking forever.
So, what is the procedure to do this? , without a lift
Also anybody in Metro NY want to do this job for me?
1970 Coronet RT 440 with a six pack won in a crap game. pw,pb,ps,rear defogger,ac,at, man. adj. seat
Re: Dropping the oil pan on a 440 B body
[Re: 70CoronetRT]
#1333175
11/11/12 02:30 PM
11/11/12 02:30 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
thanks for the reply, Forgive my ignorance, this may sound like a stupid question, I really don't remember, but maybe it's not in the oil pan? are you saying it's (the rod) in the timing chain area?
no, he's saying that it may have just fallen down into the pan, not rolled anywhere and MAYBE can be reached through the opening. it's worth a shot!
[Re: mikemee1331]
#1333176
11/11/12 02:37 PM
11/11/12 02:37 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
IMO dropping the oil pan is less work than the timing cover.
Why not get another magnet and fish around through the drain plug hole first? Might get lucky.
[Re: 70CoronetRT]
#1333177
11/11/12 02:39 PM
11/11/12 02:39 PM
Pacnorthcuda
I removed the plug, shoved the rod in there and I heard Kerplunck!
Are you sure that Kerplunk wasn't just the rod sliding down in its bore when you let go? They will do that! You can use grease to make them stay while you put the pump on.
[Re: 70CoronetRT]
#1333179
11/11/12 04:05 PM
11/11/12 04:05 PM
Pacnorthcuda
I already tried fishing around with a magnet. Besides the magnet from the last pickup tool is somewhere in there.
What's the best way to drop the pan?
Remove the center link from the pitman and the idler--DON'T remove it from the tie-rods--this will allow it to drop about 6 inches and the pan will clear. If you're lucky you can access all 20? pan bolts (the forward ones can be tough depending on pan style and how tight it is at the K frame.
Pretty easy stuff.
[Re: 70CoronetRT]
#1333180
11/11/12 08:11 PM
11/11/12 08:11 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
No , but with the timing cover off you could retrieve it that way , does the motor have a windage tray ? It might be on that ?
[Re: 70CoronetRT]
#1333185
11/14/12 11:52 PM
11/14/12 11:52 PM
JohnRR
Hey , I appreciate the replies, but what is wrong with a little clarity for my piece of mind? After all, i'm the one laying on the cold ground to do this.
"Those who can't do anything teach. Those who can't teach become art critics"
i went and dug out a partially assembled engine, there isn't a lot of room for it to go far with the timing chain installed and the cover in the way. looks like you had to have it in just the right , actually wrong , postion to have it drop , good luck
