Re: Dropping the oil pan on a 440 B body [Re: JohnRR] #1333186
11/17/12 06:06 PM
11/17/12 06:06 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I just finished removing the oil pan in my Road Runner and I DID have to jack up the engine, but not much. Granted, I have an aftermarket 7 qt. pan, but I don't see how you could get at three of the four front pan bolts without jacking the engine up. Maybe some of you "real" mechanics have some fancier sockets or something, but I couldn't get at those bolts with my "shade tree" mechanic tools.
Re: Dropping the oil pan on a 440 B body [Re: pinkduster] #1333187
11/18/12 01:04 AM
11/18/12 01:04 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
...I don't see how you could get at three of the four front pan bolts without jacking the engine up.
1/4" drive ratchet with a short 1/2" socket.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Dropping the oil pan on a 440 B body [Re: 68LAR] #1333188
11/18/12 01:58 AM
11/18/12 01:58 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Yes, that's what I was using.
Re: Dropping the oil pan on a 440 B body [Re: pinkduster] #1333189
11/18/12 11:06 AM
11/18/12 11:06 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I use a 1/4" ratchet with short 1/2" socket for the front 4 bolts. (I reach the front bolts from under the front of the car). The side bolts, I use a combination of long and short extensions with the same ratchet and socket. Never have a problem reaching any bolts and I also have a deep oil pan with a windage tray. I drop the center link at the idler arm and at the pitman arm. Pull it down for clearance and the pan comes right out. I think it takes longer to drain the oil than to do everything else.
