Re: SB Head Choices
[Re: 540challenger]
#1332212
11/09/12 01:21 PM
11/09/12 01:21 PM
Posts: 25 Texas, USA
razoreyes45k
Texas, USA
You're right about the valve-train setup. I read the article how SAM did a 414 buildup a few years ago using the same heads you mention. The combo worked out great. But here's where I differ: Where SAM opened up the Intake Ports from 176 cc to 190cc, I look to have at least 200cc for my 422. The factory and the Eddy replacement street heads all share the same (cursed) pushrod-pinch that hinders CSA. I don't want that even if it can be sleeved with brass tubes. If I'm going to spend money on NEW aluminum castings, they're going to be better than what the factory offered. I'm also looking at the Eddy Victor and Brodix B1BA Heads as a comparison. Thanks for the nice pic too. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: SB Head Choices
[Re: razoreyes45k]
#1332215
11/09/12 02:02 PM
11/09/12 02:02 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
![](/ubbthreads/images/graemlins/Twocents.gif) For the 520-550HP range you DO NOT need anything exotic. 2.10 intake valve... waste of time! Throw that max hp theory out the window, you aren't playing on that field with your HP goal. A 2.02-2.05-2.08 will feed it fine. Make sure the port is capable. Don't get caught up in a "theory" build, it will likely be a mess and cost you more money than it should. Talk to the guy that built the car craft 620hp stroker, IMM. He can sift through the static to get you something that will run well.
Re: SB Head Choices
[Re: RobX4406]
#1332216
11/09/12 02:13 PM
11/09/12 02:13 PM
razoreyes45k
Texas, USA
Thanks for your opinion and testimony. How's your stroker motor working for you ? ![](/ubbthreads/images/graemlins/beer.gif) BTW, all this tech talk boils down to one thing in my book: Other people may be happy with their engine combos but if a engine builder tells me that using a 2.100" Intake valve for my 422 will be better, I'll use his idea. What I never want to see is the tail-end of a Chevy or Ford after I cross 1,320 ft. 520-550 HP was just an estimate, not a goal. And even if my Mopar loses, the other guy's motor better be on the verge of explosion. Yes, I agree with straight ports, radiusing corners and valve guides,a bowl blend and a good 3 angle valve job too. ![](/ubbthreads/images/graemlins/2491406-danstruck.gif)
Re: SB Head Choices
[Re: razoreyes45k]
#1332217
11/09/12 02:34 PM
11/09/12 02:34 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
a lot of the guys on this forum ARE engine builders, professional engine builders who do "max effort, budget is no concern" builds...so don't be so quick to dismiss them and take the word of your local guy as gospel.
who IS your local guy anyway? what are his credentials?
No offense, but you seem to contradict yourself... you say that this is an all out, money is no concern, max hp build...then state that you're only after a mild 500-550 hp.
Box stock edelbrock heads are nearly good enough to get you there for $1500. spend another $500 on porting, and you've got a set of heads that will EASILY make 600 hp., why spend all the time and money worrying about maximum size valves on exotic heads when your hp goals aren't all that high?
are you using an R3 type block? or a stock production block?
**Photobucket sucks**
Re: SB Head Choices
[Re: 70Cuda383]
#1332218
11/09/12 02:57 PM
11/09/12 02:57 PM
razoreyes45k
Texas, USA
Whhooowww ......... Hold -on to your hat, Cowboy. You don't have to get emotional here. The election is over and Obamanation will unfortunately continue for now. Politics and emotions aside, I did not say that this is an "all out" motor. If I did, I wouldn't even bother with a production block. K? Since you ask who my "engine man" is, I have none. But if you ask who I listen to, they are: 1. Judd Massinghill 2. Steve Vance 3. Chris Bennett 4. Shawn Hooper 5. Chris Myers 6. John Witt Their credentials? Winners of the 2012 Engine Masters Challenge I started this thread because my build-up stage is still a ways away from the purchase of a set of heads and I'm using the internet to research, fact-find and consult with experienced owners on the best combination of parts and techniques to assemble my project. Nowhere have I berated or demeaned anyone's intelligence or have said that anyone is wrong. If you feel offended, I'm not to blame. I habitually thank people for their input and research claims as throughly as I can. What's wrong with the Eddy's you ask ? I don't know but they don't seem to advocate an Intake valve larger than 2.020". Not saying that it's a bad head, no. Just stating that the stroker motors can handle more according to some experts, namely: Reher Morrison for one. Relax bud. ![](/ubbthreads/images/graemlins/smoke.gif)
Re: SB Head Choices
[Re: razoreyes45k]
#1332219
11/09/12 03:18 PM
11/09/12 03:18 PM
RobX4406
Look at DJV's build 2.055 valve and 620hp, Brian 2.08/620hp, Bryce 2.08/630hp.
Still think you need a 2.10 valve?
All have a little different twist to them, but get good power. Would a 2.10 valve be better, I personally doubt it for the level they were going after. Sometimes bigger is not always better as issues arise up stream from the valve that can't effectively be overcome.
Eddy's can take a 2.02-2.08 valve. Most of the aftermarket alum replacement style heads start with a 2.02. It's an OEM factory sizing.
Just food for thought.
It's ultimately up to you and how you spend your money. Like I say, NOBODY will spend your money faster than OTHER people!
My suggestion, pick an HP goal and build to the goal. Max theory sizing is not always necessary and not worth time, money, effort when an easier, less expensive solution is available and proven to work for your goal.
Pick your parts, pay your money.
Re: SB Head Choices
[Re: RobX4406]
#1332220
11/09/12 03:38 PM
11/09/12 03:38 PM
razoreyes45k
Texas, USA
Points well made and worth investigating. I did read the Carcraft 620 HP article. Those were Eddy heads but I was adressing another post who was advocating the use of "Airwolf 220" heads who promote that they perform very well. My research affirms your basic claim to the effectiveness of Edelbrock Performers and there's no argument there. I just want to hear from a variety of owners who used different brands. A fair asessment is only logical and is always good for research and recording data. Thank you ![](/ubbthreads/images/graemlins/wave.gif)
Re: SB Head Choices
[Re: razoreyes45k]
#1332221
11/09/12 07:09 PM
11/09/12 07:09 PM
70Cuda383
Marysville, O-H-I-O
I am relaxed ![](/ubbthreads/images/graemlins/laugh2.gif) I wasn't all emotional in my post. All I was saying was that it sounded like you were being quick to dismiss "a bunch of random forum guys" over your engine builder, and I was simply pointing out that the folks on Mopars are not exactly "a bunch of random forum guys who read an article in car craft" I'm also pointing out that your logic isn't making sense. you talk about a maximum sized valve based on some equation in relation to bore size, going for maximum air flow, in what sounds like an all out max power build, but then you turn around and say you're only shooting for a mild 500-550 hp for a street engine. As it's been said, it's your money. you can spend it however you want. If I was building a 340 based stroker, and I wanted a goal of 550 hp...My wallet is also going to have a say in that. I would use a production block, just as you, because it can easily handle the goal of 550. a full on race block is a waste of money for those power goals...but if you got money to blow, why not go with one, right? My head choice, would be mildly ported edelbrock heads or fully ported iron heads like the 2.02 R/T Magnum heads, either option would set me back about $2,000 Or, I could go with some crazy exotic fully CNC'd custom head because again, that would easily deliver 550 hp. see what I'm trying to say? your desire for a 2.100 valve is simply overkill and wasted money for the power level you want. there's a difference between "all out, money is no option, maximum performance" and "being smart with your money and spending only what you need to" At the end of the day, it's your money. Not mine. you can do as you wish! it's a free country! ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: SB Head Choices
[Re: 70Cuda383]
#1332222
11/09/12 10:42 PM
11/09/12 10:42 PM
razoreyes45k
Texas, USA
I read your postings and understood you. Maybe you didn't understand me when I mentioned that I was "researching". I get the impression that you are quick to defend your point of view judging by the defensive tone. This is a discussion, whether we are on-line or speaking person to person. Your intention to give me your opinion comes across like you are telling me what to do based on your words "if it were me", "you contradict yourself" etc. Your tone is more commanding than it is inquisitive, thoughtfull and even respectfull which doesn't encourage me to engage you in discusion.
I am a learner, and in the industry of motorsports competition, one only knows the limits through past triumphs and failures. The guy that wants to know more will eventually find his answer through honesty and a sense of bravery to journey into the unknown, and at the same time, remembering what has worked and what has failed.
I desire not to confine my thinking to what is "acceptable" in most peoples' minds because I know that what is already proven is documented by winners who have already failed thrrough trial and error and have learned from their mistakes and gone on to win. It's this way of thinking that advances ideas to create new limits and henceforth, pushes the "status quo" of the current generation to rethink what is beyond.
I don't know if my thoughts relate to your understanding, and that's fine if you disagree with my point of view. But don't accuse me of being misunderstandale or contradictive when I have initially laid out my interests to be known.
If you don't want to read my earlier posts and continue not understanding the nature of my question, then that's a stumbling block that you bring upon yourself. Don't expect me to engage in discussion with you in the future if you plan to approach me in the same condescending manner which you have already done, because I will not respond to you not out of spite but because of a lack of respect you bring to the discussion. And no legth of time of "knowledge" can change the fact that what keeps people together is mutual respect which you seem not to portray.
Please don't respond to me if you feel you have to have the "last word" to prove yourself. I have no interest to waste my thoughts and time in an argument when I can be learning something. If you do come back and engage in jeer, then your reputation will be solidified with me and the rest of the members here who value rational discussion. You will only be hurting yourself.
Re: SB Head Choices
[Re: 70Cuda383]
#1332227
11/11/12 02:53 AM
11/11/12 02:53 AM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
![](/ubbthreads/images/graemlins/shruggy.gif)
you've completely misunderstood me in one of my posts, and now seem to have a preconceived notion on my attitude or tone. I'm not being condescending, argumentative, or commanding.
Have a nice day!
Ok, now it sounds like you need a chill pill, take two and repost in the morning. ![](/ubbthreads/images/graemlins/devil.gif)
Re: SB Head Choices
[Re: razoreyes45k]
#1332228
11/11/12 03:31 AM
11/11/12 03:31 AM
RobX4406
I followed the link to the Dr. J website. The SBC 220 uses the Brodix head as foundation. The SBM 220 doesn't indicate the same. Who casts the SBM 220 ?
The sb chrysler head is a pro comp casting
Re: SB Head Choices
[Re: dezduster]
#1332229
11/11/12 04:00 AM
11/11/12 04:00 AM
razoreyes45k
Texas, USA
I hear what you're saying and it's pretty relative. When I said I planned to use this 422 in a van/truck, it will either be a (SWB Tradesman or SWB D100, both being early 1970's models). The van weighs in at 3,500 lbs. and the truck maybe around 200 lbs. less. Weight aside, the comparison is about equal to an A or E Body.
When you speak of Torque, I understand what you're saying. Torque is our friend especially in street driven vehicles. Proportionately, as TQ goes up, so does HP. When I mentioned that I envisioned the engine lasting 120k-150k miles, it was just a prediction based on the hone-job and the driving style I have. The block is already bored to it's limit, so I know there will not be another rebuild when it expires. If the heads move air and the short block can handle the load, the choice of cam plays a major role in both HP and TQ depending on the type of grind.
Thanks to another poster here, I discovered that it is possible to use a roller cam in Pre-Magnum A engines. The roller will be miles ahead of the flat-tappet in performance. Ramp speed, duration, lift, and overlap will all improve making cam selection less prohibitive especially when deciding on a cam that covers a wide range of characteristics that are good both for low and top end,idle and even fuel consumption. But I ramble. I'm looking for images with 2.08/1.60 combo to see how close the valves are.
Thanks for your input.
