Dash pad #1329821
11/02/12 10:35 AM
11/02/12 10:35 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Has anyone tried Legendary's '69-'70 B-body dash pads?
Are they up to the standards of their other products?
Metal core, I hope? Thanks.
Re: Dash pad [Re: demonH1B] #1329822
11/02/12 12:53 PM
11/02/12 12:53 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
This is the one you want from B/E&A
1888-70B $225.00
69-70 Bbody black dash pad. Constructed with foam covered steel frame and vinyl covered.
http://www.beaparts.com/list_items.aspx?body=B&cat=I&subcat=21
Re: Dash pad [Re: Dave Watt] #1329823
11/02/12 03:12 PM
11/02/12 03:12 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
1888-70B $225.00
The one I bought! Its NICE!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Dash pad [Re: JMCFAN] #1329824
11/02/12 05:35 PM
11/02/12 05:35 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
I'll third that.
Re: Dash pad [Re: 2abodymcodes] #1329825
11/03/12 10:24 AM
11/03/12 10:24 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
I take it nobody has used the pad from Legendary, yet. The ones from
BE&A are good, I used a black one a while back (different car)and was pleased, I need a blue one now. I've heard of cases where some pads
(other than black) needed to be sprayed to get the color correct.
Legendary's pads should match their other interior component colors,
I'm just concerned about the construction, I imagine it's good, just
would like a first hand opinion. Thanks.
Re: Dash pad [Re: demonH1B] #1329826
11/03/12 10:27 AM
11/03/12 10:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't be the least bit surprised if the ones Legendary sells are not actually BE&A's pads (which are all black).
The BE&A pads are super nice, I don't think you could do any better. As far as color goes that's just a can of Vinyl dye away fro whatever you want it to be, since the pads are Vinyl they accept dye VERY well.
