Re: Question about stage V hemi conversion heads.
[Re: dogdays]
#1329296
11/01/12 03:46 AM
11/01/12 03:46 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
This kit was designed at a time when there were no hemi blocks in production OEM or aftermarket. It takes many parts that are specific to itself and a good deal of machine work is needed.As far as resale it will not bring close to a real hemi.
home of the Sox and Martin Hemi Duster
[Re: 23T Hemmee]
#1329302
11/01/12 02:53 PM
11/01/12 02:53 PM
Posts: 21,255 in a cattle trailer down by th...
Guitar Jones
Hopefully, the rocker arm package comes with it, the standard Hemi rockers will not work on these heads as they take special length rockers and different rocker stands. Stage V may still make them but we all know how long that might be if they are still available. You also have to do some serious grinding on the 440 block for exhaust pushrod clearance, getting really close to water jackets depending upon how much casting shift the block might have had. Also have to run an external oil drain line from the heads down to the pan or drill and tap a fitting into the block. Like Fred said, this package was a lot more desirable when there were no aftermarket blocks available.
As I recall this is correct. If you are going for an aftermarket block just get the real deal, probably easier and cheaper to get parts for in the long run.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
