Trailer Tires? #1328172
10/29/12 04:37 PM
10/29/12 04:37 PM
Indianapolis Indiana
Jamie340 Offline OP
Jamie340  Offline OP
I will be purchasing new trailer tires this winter and would like recommendations. Towing roughly 8250 lbs. Pros and cons please. Thank you
Jamie
Re: Trailer Tires? [Re: Jamie340] #1328173
10/29/12 04:44 PM
10/29/12 04:44 PM
Locomotion Offline
Locomotion  Offline
Load Range E, preferably on 16" rims and stay away from Carlisle. I like to have a wide safety margin as far as load rating goes.
Re: Trailer Tires? [Re: Jamie340] #1328174
10/29/12 05:38 PM
10/29/12 05:38 PM
Ohio
Hemi Joe Offline
Hemi Joe  Offline
Ohio
The best that I have heard of is B.F. Goodrich! I have been on this subject numerous times before, primarily because we went through 4 of our 6 trailer tires this past year and I blame it the fact that they are Chinese Manufactured Tires. In my opinion those tires are JUNK !!! I believe that we do everything correct, such as tire pressures and rotation and taking care of them with little or no success. They either blow the sides out of them or they peel the tread off of them.
I have had a lot of other racers with the same problem. We run a 48' goose neck, tri axle enclosed w/living quarters. We also run the highest load range tires available with little or no luck. The best we have been able to get is almost 2-years of use and we do not travel all over the country, we pretty much stay close to Ohio. We need a U S Tire manufacturer to step up and start to manufacture trailer tires here in the USA.
We have talked to Cooper and they told us that they use to make trailer tires here up to about 3 years ago and no one would buy them because they were around $30.00 more than the Chinese made tires. I for one would spend the extra money, because as you know, they never blow or go flat at a good time or in nice weather or in a safe place to change the tires. We racers need to contact a manufacturer and request that they start to built trailer tires here in the USA and then back them buy using their products. GOOD LUCK - HEMI JOE
Re: Trailer Tires? [Re: Jamie340] #1328175
10/29/12 06:18 PM
10/29/12 06:18 PM
Jamie
My trailer is similar weight, 8300 to 8650 lbs on the axles, 700 on the tonque depending on how far I'm going to race and how much stuff I throw in the trailer. I use to have a lot of tire troubles on both my trucks and trailers, especailly the car trailer when i lived in the Mojave desert in SO CA, I moved to central Oregon in the spring of 2005 and have not had any tire troubles since beside running over a large rock in the rode at night Ruined both passenger side tires and rims on the trailer I have a mix of tires on that trailer now,all are 225x75x15 ST one Carlisle 8 ply D rating, two Tow Master 10 ply E rating and one other local brand E rated I carry two sparees now also and they are both D rated Chinese imports Buy the best you can find, especialy if you use the trailer in the heat of summer for long distances
Re: Trailer Tires? [Re: Cab_Burge] #1328176
10/29/12 06:46 PM
10/29/12 06:46 PM
Jamie340 Offline OP
Jamie340  Offline OP
I want to thank everyone for the responses. May I ask a couple of more questions? The Goodyear Marathon are they considered one of the best? What about using LT style tire for this amount of weight.
Thanks again
Jamie
Re: Trailer Tires? [Re: Jamie340] #1328177
10/29/12 07:16 PM
10/29/12 07:16 PM
Renton Washington
Triple Threat Offline
Renton Washington
Stick with a dedicated trailer tire. 16" and load range E preferred. Nothing will ruin a trip to the track like a blow out.
Don't skimp on cheaper tires they will tear up a trailer when they blow and cost you more $$$ in the long run.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trailer Tires? [Re: Triple Threat] #1328178
10/29/12 08:17 PM
10/29/12 08:17 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
If your stuck with a 15" rim, like most of us, find a tire with a load range "E". I only know of two brands out there, there may be more. One being Carlisle which I just switched to. I use to run the Marathons ("D" range) but could only get 3 years before they blew. When one goes, the rest will soon follow. If these don't hold up, then I think will make the jump to 16" rims. Way more options on tires. Good luck with your search!
Re: Trailer Tires? [Re: Gearhead383] #1328179
10/29/12 08:25 PM
10/29/12 08:25 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If you have a lot of time here's some good reading. Many of the guys on this link travel full time and put on lots of miles.
http://www.rv.net/forum/index.cfm/fuseac...%7B%7D/sr/1.cfm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trailer Tires? [Re: pittsburghracer] #1328180
10/29/12 09:50 PM
10/29/12 09:50 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
I personally have had the best luck with Marthons, if someone tries to give you Milestar's dont take them. Hands down worst tires I have ever had on anything.
Re: Trailer Tires? [Re: BryanRad] #1328181
10/29/12 10:08 PM
10/29/12 10:08 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Maxxis might still make a 10ply E tire in 15". Don't get caught with a LT tire on a trailer.
Re: Trailer Tires? [Re: 64Post] #1328182
10/29/12 10:39 PM
10/29/12 10:39 PM
Arizona
Chris'sBarracuda Offline
Arizona
Just bought 6 Hercules STR-235/85/R16 Load range F.. 12 ply
I took advice from trucking companies.. These have a 3980# rating.. Hauling 16000# in a 48' 5th wheel..
Nice looking tire.. $1100.00 for 6 tires
We'll see..
Chris..
Re: Trailer Tires? [Re: Jamie340] #1328183
10/29/12 11:09 PM
10/29/12 11:09 PM
Lehigh Acres, Florida
rickstershemi Offline
Thanks again
Jamie
p
my Goodyear Marathon ST's were G-Rated and 14 ply....awesome tires
Rickster
Re: Trailer Tires? [Re: rickstershemi] #1328184
10/29/12 11:20 PM
10/29/12 11:20 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Thanks again
Jamie
p
Rickster [/quote
14 ply? must on a big rig
Re: Trailer Tires? [Re: Jamie340] #1328185
10/29/12 11:21 PM
10/29/12 11:21 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I got talked into Denman Express trailer tires-{made in mexico}-, I gladly switched as I could only get 2 years on Goodyear Marathons. 225x75x15ST load range D. Not even close to a year and the Denmans were all junk and one blew the sidewall out. So then I switched backed to the Goodyear Marathons and paid about $30 a tire more. I got the trailer home with the new Goodyears and checked the air pressure and noticed --MADE IN CHINA-- written in the sidewall of my new Goodyear Marathons. They were alot better looking than the older Marathons and had a scuff guard on the sidewall. The chinese Goodyears lasted 3 years so the next set I wanted the same chinese marathons and got a made in the USA set this time. I just finished the 2nd year on this set and they are not looking so good. I think 16" is the way to go with Load range E
Re: Trailer Tires? [Re: rowin4] #1328186
10/29/12 11:32 PM
10/29/12 11:32 PM
rowin4 Offline
rowin4  Offline
I bought a set of Maxxis 225 75 15 load range E, pricey but they seem to be holding up. !6 " tires would be better but the way my Pace Shadow trailer wheel well is constructed there is not enough room to put them on . I have thought about getting out the sawz -all and the welder though. On the subject of using truck LT tires on a trailer. the side walls are not made the same and will fail from turning. If your at the track just watch the trailer tires as the guys are turning into there spot or turning in the parking lot. The tires will be skidding sideways on the pavement .
Re: Trailer Tires? [Re: rowin4] #1328187
10/30/12 12:40 AM
10/30/12 12:40 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
i had nothing but failures with goodyear 225 75 r15 d marathons. i went thru about a dozen of them, (3 on one trip)
switched to towmaster 16 E radials, never had another problem.
here is a typical marathon
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Trailer Tires? [Re: Hemi_Joel] #1328188
10/30/12 01:12 AM
10/30/12 01:12 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Does anyone still run bias-ply (non radials) trailer tires?
If so do they have the tread separation issues like a radial does?
I had a tread peel off on my enclosed trailer on the way home from MMW Gateway (put one of the spares on to get home)and it's probably gonna need a set of 4 (225/75r15 ST) before I use the trailer again.
Most of what I see out there are radials, but I know of one guy that runs bias-ply (16").
None of them seem to last for very long, but separating and blowing out on the road sucks.
Re: Trailer Tires? [Re: Gearhead383] #1328189
10/30/12 09:00 AM
10/30/12 09:00 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have had great luck with Goodyear ST tires.
I have had 4 enclosed trailers over the years and all of them had 16" wheels on them. I swear I have trailered over 200K miles with my enclosed trailers and have NEVER had a Goodyear blowout or go flat, NEVER! all mine were 16" wheels and tires.
Then I have trailered over 60K miles with my open trailer with 15" tires in the last 3 years and have had no blowouts. My open trailer is stock and no added tool boxes to make it over weight.
I also was very careful what I put in my enclosed trailers, never installed wooden kitchen cabinets or stuff like that that's does not belong in a trailer which I see all the time at the track in other peoples trailers.
I'd buy Goodyear if your asking me even if there made in china, but I would call and ask for US made tires before buying. My
I would not buy a trailer enclosed with 15" wheels. That's a way to get the price down but now you are going to have tire trouble because 15" is pushing the limits of the tire and your axles are too small also.
Hemi Joe...enclosed with living quarters are really heavy trailers and do not have a lot of payload capacity. So it makes it real easy to be overweight. Especially if you built something custom inside, lightweight is expensive. IMO it's time to remove stuff from inside your trailer to lighten it up. I'm sure you have 16" wheels on it, right?
I got lucky that all my Goodyears that I bought in the last 15 years were USA made, even the 15" that I bought from the Tire Rack in 2010. I now hear all of them are made overseas? I am going to call and ask for US made trailer tires next time I need them.
Re: Trailer Tires? [Re: Challenger 1] #1328190
10/30/12 05:55 PM
10/30/12 05:55 PM
Washington
skrews Offline
skrews  Offline
Washington
I used to sell tires, and I can tell you that all trailer tires are crap. Didn't matter what brand GoodYear, Carlisle they all fail inside of 5 years. Don't buy in to that LT tires won't work on a trailer BS. I put LT 235/75/15 C load range tires on my trailers, my fathers trailer, my uncles trailer, 3 of my racing buddies trailers. Not one issue, not one failure. If the LT tires on my 3 ton turbo diesel tow rig don't go to crap every time I turn around, seems logical that they would work as well under the trailer, and they have.
Michelin
BF Goodrich
Cooper
Good Year = worst tire brand I ever saw, nothing but advertising and gimmics. Easily the highest failure rate of all the tires I sold.
Don't buy no name tires made in 3rd world countries.
Re: Trailer Tires? [Re: skrews] #1328191
10/30/12 09:18 PM
10/30/12 09:18 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
If you can find them Maxxis is your best bet for a 15" tire, if you go to a 16 you will get a better tire and have more choices.
Two years is the norm on most trailer tires, they aren't desinged to run over 65 mph and watch a trailer tire when you turn a corner it tries to roll it off the rim. Trailer tires take a lot of punishment1
