Re: Any Interest in Smallblock 3.79" Stroke
[Re: emarine01]
#1327956
10/29/12 12:18 PM
10/29/12 12:18 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I can not believe all the people who think a shorter stroke will make more power I guarantee that if NASCAR let every one run a 4.185 bore and 4 inch stroke there is not one team that would keep running 3.125 or so strokes. Or if pro stock told every one they could add 1/2 inch stroke to whatever they are running that every team would run the bigger stroke. Or Indy car or sprint car or Formula 1 or... If you are block limited like the guy with a 9 inch deck height then maybe but a factory 9.6 deck height small block can easily swallow a 4 inch stroke with little if any grinding and even a 4.25 with a little minor grinding. Then you can make a lot more power at lower RPM so your valve train can last longer and the average between TQ peak and HP peak will tend to be a lot fatter and result in a faster car.
[Re: HotRodDave]
#1327957
10/29/12 12:54 PM
10/29/12 12:54 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Pro stock does not limit stroke. They limit the cubes at 500. Thats why they run the little stroke and huge bore. More power that way.
I just never understood the 3.79 stroke. 3.800" is much more common in higher end engines. If you have a low deck block 3.800 is about the limit for stroke.
If I had a tall block I would rather have 4.00" but nothing wrong with the shorter stroke if you don't have room.
Leon
[Re: Leon441]
#1327958
10/29/12 01:02 PM
10/29/12 01:02 PM
HotRodDave
Kalispell Mt.
NASCAR don't limit stroke either, just saying if they had the option to run longer stroke as a way to go beyond the current cube limit then they ALL would do it. Unless there is a cube limit then there is no reason to run less stroke than the maximum your block can easily handle (I am not talking compromising cam profiles or ring lands or grinding too close to water passages, just within reason)and a standard deck height SB mopar can easily handle more that a 3.79 stroke.
[Re: mopar dave]
#1327961
10/29/12 01:51 PM
10/29/12 01:51 PM
HotRodDave
Kalispell Mt.
Will the 3.79 make more power per cubic inch? yes, more total power no. A 3 inch stroke would also make more power per inch than a 3.79 but less overall HP and less forgiving of anything less than perfect shift timing and even harder on valve train... that has all been my experience.
[Re: HotRodDave]
#1327964
10/29/12 02:35 PM
10/29/12 02:35 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Have you tested that out?
I've seen 360's with the same cam/heads make the same peak HP as a 4" stroker. TQ was nowhere near the same nor were peak levels the same.
Those 3.79 arms flat out work well. You're talking a 20 cu in difference. Ask about the 340/360 difference, it's about the same here, not much.
