70 Challenger Rallye hood #1326775
10/27/12 10:27 AM
10/27/12 10:27 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I have a Rallye hood on my 70 Challenger SE. How can I tell if it's 70 or later hood? Thanx.
Re: 70 Challenger Rallye hood [Re: Gabmando] #1326776
10/27/12 11:20 AM
10/27/12 11:20 AM
western australia
1cuda Offline
1cuda  Offline
western australia
Does it have the impact creases on the inner skin? What is the build date of your car? This info will help get to an answer.
Re: 70 Challenger Rallye hood [Re: Gabmando] #1326777
10/29/12 03:52 PM
10/29/12 03:52 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The >'70 hoods will have a provision stamped into the hood where a bracket attached. This bracket is used to to secure the safety latch pull rod release.
The 1970 Challenger Rallye hood do not have this stamped into the hood.
The leading hood area where the trim attaches may be slightly different too. However, the stamping/bracing for the bracket attachment or lack of, is the easiest way to determine 1970 hood IM0.
Re: 70 Challenger Rallye hood [Re: cruzin] #1326778
10/30/12 09:02 PM
10/30/12 09:02 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
My Challenger is a late 69 build SE so it originally had a flat hood. My hood has a provision to mount a bracket (and two threaded bolt holes) so I believe it's a 72 up hood. I think 71 Rallye hoods do not have the letters D O D G E.
I wish I knew how to attach a picture on here.
Re: 70 Challenger Rallye hood [Re: Gabmando] #1326779
10/31/12 12:37 AM
10/31/12 12:37 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...I wish I knew how to attach a picture on here.
This thread may help.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4769752&Main=4767916
Re: 70 Challenger Rallye hood [Re: moparfan53] #1326780
11/02/12 12:00 AM
11/02/12 12:00 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for your help. i attached a picture of my hood.
Re: 70 Challenger Rallye hood [Re: Gabmando] #1326781
11/02/12 12:52 AM
11/02/12 12:52 AM
western australia
1cuda Offline
1cuda  Offline
western australia
what size bolts hold the hood to the hood hinges...more pics please.
all the best
frank
Re: 70 Challenger Rallye hood [Re: 1cuda] #1326782
11/02/12 01:02 AM
11/02/12 01:02 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 model year hoods have a smaller bolt thread diameter than the newer hoods, I want to say 5/16"?
I do not have one here to check for sure, it has been a while, so hopefully someone here can check.
1970 model year hood trim also attaches through the front flange of the hood. For 1971 & later it attached from the bottom.
