Re: when to upgrade from an 8 3/4? [Re: bdaz smblk] #1324962
10/23/12 10:07 PM
10/23/12 10:07 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
As mentioned above. Sell the 8 3/4 while it still is good. It will bring good money to offset your cost in going to a Dana. I used a 3/4 ton truck rear end that I narrowed and put car housing ends on it. Got some 35 spline axles w/ green bearings from Dr. Diff and all is well. Sold my 8 3/4 and when it was all said and done the Dana only cost me a little over $250 to put it in.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: when to upgrade from an 8 3/4? [Re: bdaz smblk] #1324963
10/24/12 12:51 AM
10/24/12 12:51 AM
fresno ca
mikeysmopars Offline
fresno ca
I've been 9.0's 150 at 3,200 with a 8 3/4 with 1.20 couple 60 ft.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: when to upgrade from an 8 3/4? [Re: mikeysmopars] #1324964
10/24/12 08:23 AM
10/24/12 08:23 AM
Guitar Jones Offline
Honestly if I had it to do over I'd go with a Dana. I have a lot of money in my 8.75 with a spool, the MP aluminum case and pro gears that are only available in one ratio, a 4.86, so in hindsight if you are going to have to narrow it, buy axles and all that just get a Dana and be done with it.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: when to upgrade from an 8 3/4? [Re: mikeysmopars] #1324965
10/24/12 10:43 AM
10/24/12 10:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve seen your responces to this kind of post before and am curious if you`d shoot your bad-azz combo for us to see..............
Re: when to upgrade from an 8 3/4? [Re: Guitar Jones] #1324966
10/24/12 10:46 AM
10/24/12 10:46 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have been running a 8 3/4 for the last three years at 3750 lbs and running 10.50's - 10.60's in my Charger and havent had any issuses yet. 1.48 best 60'. Probly only have just under under 100 passes.
67' charger 499 RB 10.57 at 127
Re: when to upgrade from an 8 3/4? [Re: dragram440] #1324967
10/24/12 11:02 AM
10/24/12 11:02 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v been 1.28's with mine on a 10.5w@3350 but if i was smart i'v would of did a Dana/9"
Re: when to upgrade from an 8 3/4? [Re: racerx] #1324968
10/24/12 05:34 PM
10/24/12 05:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use an 8-3/4 in my 63 and so far have run 10.70's and it still has stock axles in it. Its an auto car that goes just over 3700 lbs and other then the Detroit Locker it is all stock. Now I only race my car 2 or 3 times a year at the most and usually just a test & tune where I only make a few passes. I did not race it at all this year because of some personal problems. But I want to go to a Dana and would have if I had the money when I built my 493. If you have the cash go with the Dana as its good insurance. And if you blow the 8-3/4 you will be pulling the trans to fix the overrunning clutch (sprag). I am pushing my luck everytime I race my 63 and I know it but I can not afford a Dana right now or I would have one. Ron
Re: when to upgrade from an 8 3/4? [Re: Thumperdart] #1324969
10/24/12 09:07 PM
10/24/12 09:07 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
What all would you like to know about it.The car has a nice w8 smallblock with a 727 true 29.5 x10.5 tire with exhaust full interior including a back seat all lights work could drive it on the street if i trusted all the idiot drivers now days (LOL).If u want to know more just say.Thanks Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: when to upgrade from an 8 3/4? [Re: dirt] #1324970
10/24/12 09:17 PM
10/24/12 09:17 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
3750 lbs race ready with driver. Mark Williams spool and axles. Housing has a back brace.
Best of 10.18@ 133.04
Only broke 1 ring gear in 8 years of racing
Re: when to upgrade from an 8 3/4? [Re: actionange] #1324971
10/24/12 09:23 PM
10/24/12 09:23 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Here's the broken ring gear. Manufacturer unknown- bought center used. Upgraded to Mark Williams spool and axles after this with Richmond gears.
Re: when to upgrade from an 8 3/4? [Re: Guitar Jones] #1324972
10/24/12 09:27 PM
10/24/12 09:27 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
At 11.90 ETs an 8 3/4" ring and pinion needs to be replaced every 100 passes.
Huh, I guess my 8 3/4 didn't get that memo.
my 8 1/4 should have blown up many many years ago.. cuz im 3600lb running 12.30's...
but if your building the car now i would go 9" or dana
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: when to upgrade from an 8 3/4? [Re: bdaz smblk] #1324973
10/24/12 10:31 PM
10/24/12 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ll say..........NICE is an understatement..........9.0`s, small block n/a, 3200lbs..........that doesn`t happen everyday.........
Re: when to upgrade from an 8 3/4? [Re: Thumperdart] #1324974
10/24/12 10:39 PM
10/24/12 10:39 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Thanks your car runs dang good too.I didn't even have the car out this year but hope to lighten the car up and be racing again sometime.If i wasn't broke as a dang on joke i would have a chrome moly cage in this car and save alot of weight.LOL
Re: when to upgrade from an 8 3/4? [Re: dirt] #1324975
10/24/12 11:05 PM
10/24/12 11:05 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I am working on a scamp for a friend and its going to be a race car. I am back halfing it probably with ladder bars. The motor is a 440 and used to run 11.60 in a stock weight 70 cuda. With an automatic. He asked what i thought about the8 3/4 he has. It needs narrowed yet but he allready has it. I thought it would be fine. But now he is talking about stroking the motor and getting better heads.
So at what point would you say the 8 3/4 needs changed out for a dana 60? If there is a point.
Thanks, kenny [/quote
Right after you brake the 8 3/4 .Put a dana in and forget it for years
Re: when to upgrade from an 8 3/4? [Re: 71yelladustr] #1324976
10/25/12 12:00 AM
10/25/12 12:00 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
hey when are you going to start on my Dana??lol hey i am ether going to the track this Friday or Saturday if it rains. want to go?? Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: when to upgrade from an 8 3/4? [Re: mopar65] #1324977
10/26/12 08:09 PM
10/26/12 08:09 PM
Missouri U.S.A.
Missouri U.S.A.
Thanks for the invite Bobby. Cant go this weekend. Got to finish putting Dewaynes 496 back together for his Challenger. As for the Dana, JP up at Skyline welding cut down the tubes and made a jig to welded my ends on my rearend. I just ordered some axles from Dr. Diff and cut them with a chopsaw and slid them in. Nothing to it. Good luck at the track this weekend. Maybe next sping I'll take my junk up there and see what I can tear up.
10.02@134
Re: when to upgrade from an 8 3/4? [Re: bdaz smblk] #1324978
10/26/12 09:33 PM
10/26/12 09:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m more broke than I`ve been in years but nothing lasts forever and I`m kickin butt in college and if I can make it happen, I`ll be a smog guy/tech and have mad skills in an area that`s here to stay...........emissions baby. I`ve tried to get hot rod jobs here and there and feel like I`m kissing ass and no one has the nuts to respond back so that`s over now. Smog techs make top dollar, don`t work too hard and have great hours that I will controll. I too would love to lighten up my heap and will soon enuff a little bit at a time. Good luck to ya! peace.
