Re: More Power---Hyd. Roller or Solid Flat Tappet?
[Re: kzinge1]
#1324443
10/22/12 09:40 PM
10/22/12 09:40 PM
Posts: 4,648 aotearoa
rebel
aotearoa
Sounds like the roller is the way to go! Good because it will actually be cheaper for me. Just have to limit the RPM to 6k.
those Stealth heads will help with that.
[Re: rebel]
#1324444
10/22/12 09:54 PM
10/22/12 09:54 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
i have a hyd roller in a 440 i just build. im a little less than impressed. its probably gonna be coming out for a solid flat tappet in the near future.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#1324445
10/22/12 10:19 PM
10/22/12 10:19 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
I vote for the solid flat tappet for sure, but add 1.6 rockers.
[Re: kzinge1]
#1324446
10/22/12 10:33 PM
10/22/12 10:33 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
I do not know exactly what the heads flow. They are untouched stealths so I think they flow a little less than the RPM heads. The solid cam is relatively low lift but has good duration. Also, I am not limited to that cam, I can buy another one. The only thing that worries me about the hydraulic is the RPM limit. I just tore up my 511 stroker motor after spinning it to about 6300 with the hyd roller. But its low maintenance, I have all the parts for it and don't have to worry about wiping a cam. Just have to set my rev limiter to 6K. Static Compression is 11-1
When I was looking into a different cam set up, I was going back and forth with a solid vs a hyd roller as you are. I ended up calling Bullet Cams and they set me up with a hyd roller. I'm running eddy rpms (on a 470) vs your heads, they are basically untouched except for a valve job. The specs on my roller are @ 050, 249in 253out gross lift 573. I buzz it up to 6400 and it pulls hard all the way. Bullet is a good company to work with, and were extremely helpful.
[Re: kzinge1]
#1324448
10/22/12 11:34 PM
10/22/12 11:34 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Here's my combo:
426" Wedge, Stealth heads, Harland Sharp rockers, RPM intake, 750 Demon, 2" TTIs Street/ Strip 69 Roadrunner, 3.54 Dana, 727 w/ 3500 stall 9" converter.
I have a Hyd. Roller setup that is .549/.544 lift 242/248 dur. @.050 and also a solid flat Tappet that is .525/.525 lift 248/248 dur. @.050
Which cam would you guys prefer with this setup? Also feel free to recommend something else as well.
Not seeing a huge difference between the two. Do you have the advertised and .200" numbers? The hydraulic is probably slow off the seat and will probably be a little softer at lower rpm than the solid. The Stealth, out of the box flow numbers at .50 and .55 are not much different, so the 0.050" lift advantage of the hydraulic won't mean that much.
Any hydraulic should be able to live trouble free well above 6000 rpm, but I dont see your combinations wanting much more.
[Re: Mr.Yuck]
#1324450
10/23/12 01:22 AM
10/23/12 01:22 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I'd wager at least by 1/2 second in the 1/4 mile.
Im assuming your flat tappet is a Comp 294S?? Which is a lazy lobe, 154 @.200. Dont know what brand your hyd roller is, but comparing it to some lobes in the Comp book, Id figure its around 164ish @.200. Id guess .1-.15 et difference at best between the 2.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: kzinge1]
#1324454
10/23/12 01:21 PM
10/23/12 01:21 PM
BradH
OK: - More gear -->3.91 - 4.10 - Bigger carb --> 850-ish - Smaller headers --> 1-7/8" - Port the heads, rather than run them "out of the box"
And then - maybe - the hyd. roller cam might be an OK fit... and that depends on the LSA, your compression, etc.
[Re: BradH]
#1324456
10/23/12 01:58 PM
10/23/12 01:58 PM
Posts: 2,826 NY usa
540challenger
NY usa
Just want to touch one thing hear about the carb
The 750 demon carbs are underrated the 750 flows closer to a 850 cfm carb.
