70 Charger - front wheel/tire combo -what's yours? #1324245
10/22/12 03:15 AM
10/22/12 03:15 AM
Texas
E
ef8Cuda340 Offline OP
E
Texas
I am trying to find the best front tire combination for my 70 Charger. So far I've tried 15x8.5 Centerline Drag Lites with a 3-7/8" offset (I may have to double check) using 255/60 BFGs and they rubbed on the forward side of the wheel lip. Then I tried a set of Centerlines that are 15x7s with a 4-7/8" offset (again, I may have to verify) using the same tires but these appear to narrow in the wheel well, but don't rub.
I am looking for a comparable tire that will be slightly smaller in sidewall to the rear L-60s. I don't mind if I use a 70 series tire, but I don't want them tucked in too far into the wheel well.
Any thoughts, pictures, etc would be greatly appreciated.
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: ef8Cuda340] #1324246
10/22/12 09:48 AM
10/22/12 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
15x4 w/ a 205/75/15 But I get the feeling you want more tine than that. Probably 15x7 w/ a 225/70/15 would work for you. I can't imagine having a tire as big ass a 255/60 up front. A 225/70 is 27.4" tall and has s section width of about 8.8" A 215/75 is 27.7" tall with a section width of 8.5. These are both close to the height (28") and width (10.8") of your rear tires. Go here for more tire specs...
http://www.1010tires.com/tiresizecalculator.asp
Coming soon!!!!
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: Mr.Yuck] #1324247
10/22/12 10:13 AM
10/22/12 10:13 AM
Central NC
gch Offline
gch  Offline
Central NC
try a 15x8 with 4.5 backspace.275/60/15.It may not fit on a 70 but it worked like a charm on my 73.
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: ef8Cuda340] #1324248
10/22/12 10:34 AM
10/22/12 10:34 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have a 15X7 rim, 4.250" backspace(Chrysler Rallye), running a Goodyear 255X60X15 on the front of my 70 Charger, no rubbing, fender or frame, just about the max backspacing with that tire, as it just clears the frame at full lock
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: DAYCLONA] #1324249
10/22/12 05:42 PM
10/22/12 05:42 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am running 235/60/15 BFG on a 15x7 rim with 4.5" backspace on the front. On the rear I am using 295/50/15 BFG on a 15x10 rim with a 5" backspace. The rims are Magnum 500s.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: 70sixpkrt] #1324250
10/23/12 01:14 PM
10/23/12 01:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here except my rears are on 8" Rallye's.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 70 Charger - front wheel/tire combo -what's yours? [Re: gch] #1324251
10/23/12 08:16 PM
10/23/12 08:16 PM
Central NC
gch Offline
gch  Offline
Central NC
duh you asked for the front.I ran 255/6015 on 7" wheel or 225/7015 on the same wheel.
