Page 3 of 3 1 2 3
Re: 4 speed trans: Condition and determining gearsets? [Re: Cab_Burge] #1324107
10/24/12 02:59 PM
10/24/12 02:59 PM
So Cal
autoxcuda Offline OP
So Cal
Those are the stock steel forks, I would use them
Would/should you file down the gouge? Is a thinner cross section there going to create some looseness somewhere?
I did a older 2.66 box for a customer several years back, I sent his gears to Liberty to have them replace the engagemnet teeth ring,and they converted them to Pro Shift I called them back and ask why did they do that instead of replacing the rings with stock ones, thier explanation was that stock ones aren't availble. I had told them that this box was a street box, not a race box He siad put it together and drive it and then call them back, it would work fine It DID
The clutching teeth are part of the gear, correct? So does liberty have a way of putting new teeth on it or do they modify the old teeth?
Re: 4 speed trans: Condition and determining gearsets? [Re: autoxcuda] #1324108
10/24/12 03:38 PM
10/24/12 03:38 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
I would contact Jamie and ask if you could ship the parts to him for inspection, minus the case and tailshaft of course. Replace what it needs and install it, once and done .
Re: 4 speed trans: Condition and determining gearsets? [Re: autoxcuda] #1324109
10/24/12 10:43 PM
10/24/12 10:43 PM
I would not touch the forks, it(the slider) will ride on the high parts Liberty cuts the ring that the small steel teeth are on off and welds a new ring on the old gear with the bigger pro shifted lugs on them I don't have any pictures of the pro shifted lugs but theyr'e no where near looking like the stock factory gears look Maybe someone else can type a link in on here showing the pro shifted lugs and the faceplated gears together
Re: 4 speed trans: Condition and determining gearsets? [Re: autoxcuda] #1324110
10/25/12 10:26 AM
10/25/12 10:26 AM
Sugarloaf, PA. USA
JamiePasson Offline
JamiePasson  Offline
Sugarloaf, PA. USA
Forks look womped. The synchro teeth on the speed gears are nothing to write home to mom about either. Input doesn't look horrible. One thing no one is considering is wear on the coast side of the synchro teeth. I cannot tell you how many gears we have canned with PERFECT points that popped out of gear because the coast side of the teeth are worn so bad. Put them in a box and send them over. I will gladly look at the stuff for no charge and get you headed in the right direction. By the way, it IS a 2.47 ratio unit. I am very hesitant to diagnose synchro teeth by a digital picture of an oily dirty gear. You just cannot see the detail needed.
Let me know if you need help.
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: 4 speed trans: Condition and determining gearsets? [Re: Cuda340] #1324111
10/25/12 11:05 PM
10/25/12 11:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm just a little too far away to drop by Pennsylvania to his shop.
Looks like he cuts/files the clutching teeth down to get the point/triangle back again. But tough to see in the picture on his website of reconditioned gears.
Yes you can re-dress the clutching teeth back to original shape if they are not too bad...
I've seen worse , I use a dremel with a small stone and put the points back and smooth down the chips , it they are real bad you can send just the gears to Passon , Brewer or Liberty ...
I'm with Jamie on the forks , the person that put the most miles on that trans did it with his hand resting on the shifter. One MIGHT be able to dress those flat and smooth again and not weaken them too much .
Re: 4 speed trans: Condition and determining gearsets? [Re: JamiePasson] #1324112
10/26/12 11:18 PM
10/26/12 11:18 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Jamie
Yep, as told to me by Paul at Liberty Gear, the 3 linear cuts on the tips of the gearteeth are for the assembly line worker to be able to quickly identify that ratio for assemby.
That's what mine checked out as.
Re: 4 speed trans: Condition and determining gearsets? [Re: Dean_Kuzluzski] #1324113
10/29/12 12:03 AM
10/29/12 12:03 AM
Sugarloaf, PA. USA
JamiePasson Offline
JamiePasson  Offline
Sugarloaf, PA. USA
Actually, the grooves were for the parts guys pulling and dealers ordering parts. The 2.66 and 2.47 ratios were not built at the same time in the factory. The 2.66 and 2.47 ratios have the same tooth counts for second and third gear. But don't listen to me, I don't know what I am talking about.
Re: 4 speed trans: Condition and determining gearsets? [Re: JamiePasson] #1324114
10/29/12 12:15 AM
10/29/12 12:15 AM
So Cal
So Cal
So are the 2nd and 3rd mainshaft gears interchangable between 2.66 and 2.47 trans'?
Re: 4 speed trans: Condition and determining gearsets? [Re: autoxcuda] #1324115
10/29/12 10:55 AM
10/29/12 10:55 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
NO.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Page 3 of 3 1 2 3
