Edelbrock Carb Question #132368
10/05/08 07:17 AM
10/05/08 07:17 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
On the instructions that came with my Edelbrock carb the front vacumn port is designated for the PCV hose and the rear for power brake vacumn. Can the rear port be used for PCV?
Re: Edelbrock Carb Question [Re: TooMany62s] #132369
10/05/08 08:26 AM
10/05/08 08:26 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
i use the one in rear for the power steering's brake boost vacuum.
the front i use for CV, its just closer.
look at the porting for the holes on under side the carb. they will tell you what pull from manifold vacuum.
Re: Edelbrock Carb Question [Re: TooMany62s] #132370
10/05/08 09:23 PM
10/05/08 09:23 PM
Northeast Ohio
B9ChargerSE440 Offline
Northeast Ohio
I used the one on the front for the pcv and plugged off the one in the back and used the port on my air gap intake for the power brakes!
Re: Edelbrock Carb Question [Re: B9ChargerSE440] #132371
10/06/08 10:23 AM
10/06/08 10:23 AM
scratchnfotraction Offline
yes you can
front or back for brake booster or pcv valve
you can use a port in the intake for the booster also
its all manifold vac in these 3 spots
the dist vac would go on the pass side of carb looking at it
the other side is full manifold vac and I use it for a S&W vac gauge I installd in the cab
