Page 2 of 3 1 2 3
Re: How high do you rev your motor [Re: Mr.Yuck] #1323602
10/21/12 02:18 PM
10/21/12 02:18 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
505" RB, max wedge victors, shift at 6500, cross stripe at 7100. Have 7200 chip in the limiter.
Re: How high do you rev your motor [Re: Kam*Kuda] #1323603
10/21/12 05:28 PM
10/21/12 05:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
shift at 9800, if I'm 1/10th of second late I'm at 10400. clutch don't even come in until 8900 rpms.
Re: How high do you rev your motor [Re: Challenger 1] #1323604
10/21/12 05:33 PM
10/21/12 05:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Usually rev it til it blows up then back off about 200 rpm...
Re: How high do you rev your motor [Re: RobX4406] #1323605
10/21/12 06:27 PM
10/21/12 06:27 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
with my stock block 408 I shift at 6800 and across the stripe at 7200.
Re: How high do you rev your motor [Re: dartman366] #1323606
10/21/12 07:12 PM
10/21/12 07:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
440sb. shiftin at 6800, 7000-7100 at the stripe.
Re: How high do you rev your motor [Re: rickraw] #1323607
10/21/12 08:01 PM
10/21/12 08:01 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Had my old 426 Hemi built to 1973 prostock spec, ran it to 9000 once and 8800 numerous times (Jones-Motorola mech. tach). Torque below 4500 was low. This was with heavy TRW pistons, Nascar rods, 4-speed, R290 and triple springs. Street use only, finally a rodbearing let go and took the Kellog crank journals 5 and 6....
Re: How high do you rev your motor [Re: Oyvind Mopar] #1323608
10/21/12 10:12 PM
10/21/12 10:12 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Wow Quite the range.
9500-10000 rpm
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: How high do you rev your motor [Re: RobX4406] #1323609
10/21/12 10:14 PM
10/21/12 10:14 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thats always good advice LOL
1654.5 Mustang
1955 Land Rover
Re: How high do you rev your motor [Re: Kam*Kuda] #1323610
10/21/12 10:22 PM
10/21/12 10:22 PM
Missouri
galen Offline
galen  Offline
Missouri
588 grp rods, 4.625 stroke in the boat 7400
Re: How high do you rev your motor [Re: Al_Alguire] #1323611
10/21/12 10:28 PM
10/21/12 10:28 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Well you asked for it. The 499" Hemi we shift at 9500 cross the stripe at about 9900-10200 depending on gear and DA.
The 525" B1 when on the odd occasion I run it all out I shift at 8300. It does not have enough gear or converter for running all out and I cross the stripe at a pedestrian 7450.
Al what's the bore/stroke on that engine? i'm figuring stroke in the 3.5-3.6" range and bore 4.7ish?
as for the OP question, no faster than i have to. too fast in the burnout though (probably 7600-7700) leaving 3400, shifting 6800, crossing around 7-7200
Re: How high do you rev your motor [Re: jamesc] #1323612
10/21/12 10:44 PM
10/21/12 10:44 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Stock stroke, cast crank 360- cross the stripe at 71-7200.
Re: How high do you rev your motor [Re: bill_greenwood] #1323613
10/22/12 12:36 AM
10/22/12 12:36 AM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
I know a guy that spun a stock 67 440 shortblock 7000 on the launch, shifted at 7200.
Stock rod bolts and all, he did this every Sunday for two years
Re: How high do you rev your motor [Re: GTX MATT] #1323614
10/22/12 12:46 AM
10/22/12 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
405ci SB ... 8200 almost always... have been to 9600
to see if it had power up there
Re: How high do you rev your motor [Re: MR_P_BODY] #1323615
10/22/12 01:40 AM
10/22/12 01:40 AM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
I shift when the oil light comes on
Re: How high do you rev your motor [Re: jamesc] #1323616
10/22/12 02:36 AM
10/22/12 02:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
James, the Hemi is 4.700" bore 3.600" stroke.
Re: How high do you rev your motor [Re: gillman34] #1323617
10/22/12 07:40 AM
10/22/12 07:40 AM
gregsdart Offline
gregsdart  Offline
I shift a 7100, trap 7400. 4.15 stroke 528, 440-1 heads.
Re: How high do you rev your motor [Re: gregsdart] #1323618
10/22/12 07:58 AM
10/22/12 07:58 AM
Guitar Jones Offline
The old W5 340, 8000
The old stock bottom end 360, 7200
The new 408, 7000
Re: How high do you rev your motor [Re: Guitar Jones] #1323619
10/22/12 08:25 AM
10/22/12 08:25 AM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
Limiter at 9500. Shift around 9200.
358ci R5P7 SB.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: How high do you rev your motor [Re: 77DragracerR/T] #1323620
10/22/12 11:00 AM
10/22/12 11:00 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
408" 6500-7000 no need for more, it pull right to it and Ive never needed to go more.
Re: How high do you rev your motor [Re: Moparnut426] #1323621
10/22/12 11:26 AM
10/22/12 11:26 AM
Ma
Voluster Offline
Voluster  Offline
Ma
I thought I was zinging indy headed small block stroker to 7k was high you guys rev them to the moon
Page 2 of 3 1 2 3
