Re: How high do you rev your motor
[Re: Al_Alguire]
#1323611
10/21/12 10:28 PM
10/21/12 10:28 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Well you asked for it. The 499" Hemi we shift at 9500 cross the stripe at about 9900-10200 depending on gear and DA.
The 525" B1 when on the odd occasion I run it all out I shift at 8300. It does not have enough gear or converter for running all out and I cross the stripe at a pedestrian 7450.
Al what's the bore/stroke on that engine? i'm figuring stroke in the 3.5-3.6" range and bore 4.7ish?
as for the OP question, no faster than i have to. too fast in the burnout though (probably 7600-7700) leaving 3400, shifting 6800, crossing around 7-7200
[Re: bill_greenwood]
#1323613
10/22/12 12:36 AM
10/22/12 12:36 AM
Posts: 5,173 CT
GTX MATT
CT
I know a guy that spun a stock 67 440 shortblock 7000 on the launch, shifted at 7200. Stock rod bolts and all, he did this every Sunday for two years
[Re: jamesc]
#1323616
10/22/12 02:36 AM
10/22/12 02:36 AM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
James, the Hemi is 4.700" bore 3.600" stroke.
[Re: gregsdart]
#1323618
10/22/12 07:58 AM
10/22/12 07:58 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
The old W5 340, 8000 The old stock bottom end 360, 7200 The new 408, 7000
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
