Re: How high do you rev your motor
[Re: tsanchez]
#1323624
10/22/12 04:50 PM
10/22/12 04:50 PM
Posts: 3,695 nc
emarine01
nc
[Re: emarine01]
#1323625
10/22/12 06:50 PM
10/22/12 06:50 PM
Posts: 37 SD
SG5438
SD
572 - shift at 7500 and cross at 7800
2015 3500 Mega Cab Cummins 1970 Plymouth GTX - 7.99 @ 170 @ Bandimere
[Re: WHITEDART]
#1323628
10/23/12 12:41 AM
10/23/12 12:41 AM
Posts: 903 Saskatchewan, Canada
cudabin
557" - shift at 7,600 and trap at 8,000 - 8,100 rpm
Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: BradH]
#1323630
10/23/12 01:45 PM
10/23/12 01:45 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
470, 456 gears ,30" tires chip is 7600 and i use it all.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: BradH]
#1323632
10/23/12 05:03 PM
10/23/12 05:03 PM
Posts: 3,210 robin hood country
deaks
robin hood country
440 w/ light pistons, good rods & forged crank... shifting 6300 and going thru 1/4-mile traps at 6800-7000. These #s might go up a couple of hundred RPM w/ new rebuild, so I've switched from OEM crank to an aftermarket 4340 piece.
Likewise but i go through the line at 6700, if i shift much higher than 6300, the power drops off. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
