Page 2 of 3 1 2 3
Re: How high do you rev your motor [Re: Mr.Yuck] #1323602
10/21/12 02:18 PM
10/21/12 02:18 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
505" RB, max wedge victors, shift at 6500, cross stripe at 7100. Have 7200 chip in the limiter.
Re: How high do you rev your motor [Re: Kam*Kuda] #1323603
10/21/12 05:28 PM
10/21/12 05:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
shift at 9800, if I'm 1/10th of second late I'm at 10400. clutch don't even come in until 8900 rpms.
Re: How high do you rev your motor [Re: Challenger 1] #1323604
10/21/12 05:33 PM
10/21/12 05:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Usually rev it til it blows up then back off about 200 rpm...
Re: How high do you rev your motor [Re: RobX4406] #1323605
10/21/12 06:27 PM
10/21/12 06:27 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
with my stock block 408 I shift at 6800 and across the stripe at 7200.
Re: How high do you rev your motor [Re: dartman366] #1323606
10/21/12 07:12 PM
10/21/12 07:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
440sb. shiftin at 6800, 7000-7100 at the stripe.
Re: How high do you rev your motor [Re: rickraw] #1323607
10/21/12 08:01 PM
10/21/12 08:01 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Had my old 426 Hemi built to 1973 prostock spec, ran it to 9000 once and 8800 numerous times (Jones-Motorola mech. tach). Torque below 4500 was low. This was with heavy TRW pistons, Nascar rods, 4-speed, R290 and triple springs. Street use only, finally a rodbearing let go and took the Kellog crank journals 5 and 6....
Re: How high do you rev your motor [Re: Oyvind Mopar] #1323608
10/21/12 10:12 PM
10/21/12 10:12 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Wow Quite the range.
9500-10000 rpm
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: How high do you rev your motor [Re: RobX4406] #1323609
10/21/12 10:14 PM
10/21/12 10:14 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thats always good advice LOL
1654.5 Mustang
1955 Land Rover
Re: How high do you rev your motor [Re: Kam*Kuda] #1323610
10/21/12 10:22 PM
10/21/12 10:22 PM
Missouri
galen Offline
galen  Offline
Missouri
588 grp rods, 4.625 stroke in the boat 7400
Re: How high do you rev your motor [Re: Al_Alguire] #1323611
10/21/12 10:28 PM
10/21/12 10:28 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Well you asked for it. The 499" Hemi we shift at 9500 cross the stripe at about 9900-10200 depending on gear and DA.
The 525" B1 when on the odd occasion I run it all out I shift at 8300. It does not have enough gear or converter for running all out and I cross the stripe at a pedestrian 7450.
Al what's the bore/stroke on that engine? i'm figuring stroke in the 3.5-3.6" range and bore 4.7ish?
as for the OP question, no faster than i have to. too fast in the burnout though (probably 7600-7700) leaving 3400, shifting 6800, crossing around 7-7200
Re: How high do you rev your motor [Re: jamesc] #1323612
10/21/12 10:44 PM
10/21/12 10:44 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Stock stroke, cast crank 360- cross the stripe at 71-7200.
Re: How high do you rev your motor [Re: bill_greenwood] #1323613
10/22/12 12:36 AM
10/22/12 12:36 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I know a guy that spun a stock 67 440 shortblock 7000 on the launch, shifted at 7200.
Stock rod bolts and all, he did this every Sunday for two years
Re: How high do you rev your motor [Re: GTX MATT] #1323614
10/22/12 12:46 AM
10/22/12 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
405ci SB ... 8200 almost always... have been to 9600
to see if it had power up there
Re: How high do you rev your motor [Re: MR_P_BODY] #1323615
10/22/12 01:40 AM
10/22/12 01:40 AM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
I shift when the oil light comes on
Re: How high do you rev your motor [Re: jamesc] #1323616
10/22/12 02:36 AM
10/22/12 02:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
James, the Hemi is 4.700" bore 3.600" stroke.
Re: How high do you rev your motor [Re: gillman34] #1323617
10/22/12 07:40 AM
10/22/12 07:40 AM
gregsdart Offline
gregsdart  Offline
I shift a 7100, trap 7400. 4.15 stroke 528, 440-1 heads.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: How high do you rev your motor [Re: gregsdart] #1323618
10/22/12 07:58 AM
10/22/12 07:58 AM
Guitar Jones Offline
The old W5 340, 8000
The old stock bottom end 360, 7200
The new 408, 7000
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: How high do you rev your motor [Re: Guitar Jones] #1323619
10/22/12 08:25 AM
10/22/12 08:25 AM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
Limiter at 9500. Shift around 9200.
358ci R5P7 SB.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: How high do you rev your motor [Re: 77DragracerR/T] #1323620
10/22/12 11:00 AM
10/22/12 11:00 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
408" 6500-7000 no need for more, it pull right to it and Ive never needed to go more.
Re: How high do you rev your motor [Re: Moparnut426] #1323621
10/22/12 11:26 AM
10/22/12 11:26 AM
Ma
Voluster Offline
Voluster  Offline
Ma
I thought I was zinging indy headed small block stroker to 7k was high you guys rev them to the moon
Page 2 of 3 1 2 3
