Re: How high do you rev your motor
[Re: Al_Alguire]
#1323611
10/21/12 10:28 PM
10/21/12 10:28 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Well you asked for it. The 499" Hemi we shift at 9500 cross the stripe at about 9900-10200 depending on gear and DA.
The 525" B1 when on the odd occasion I run it all out I shift at 8300. It does not have enough gear or converter for running all out and I cross the stripe at a pedestrian 7450.
Al what's the bore/stroke on that engine? i'm figuring stroke in the 3.5-3.6" range and bore 4.7ish?
as for the OP question, no faster than i have to. too fast in the burnout though (probably 7600-7700) leaving 3400, shifting 6800, crossing around 7-7200
[Re: bill_greenwood]
#1323613
10/22/12 12:36 AM
10/22/12 12:36 AM
Posts: 5,167 CT
GTX MATT
CT
I know a guy that spun a stock 67 440 shortblock 7000 on the launch, shifted at 7200. Stock rod bolts and all, he did this every Sunday for two years
[Re: jamesc]
#1323616
10/22/12 02:36 AM
10/22/12 02:36 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
James, the Hemi is 4.700" bore 3.600" stroke.
[Re: gregsdart]
#1323618
10/22/12 07:58 AM
10/22/12 07:58 AM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
The old W5 340, 8000 The old stock bottom end 360, 7200 The new 408, 7000
