66 hemi 4 speed clutch vibration? #1323368
10/20/12 02:46 PM
10/20/12 02:46 PM
N.Y.
sixpacksteve Offline OP
N.Y.
i installed my 11'hayes clutchupon putting the fork in w/throw bearing
it wouldn't fit. so i learned mopar makes 3 different throwout bearings.
got the shortest 1 from SK Speed its 1.46 bearing to fork pad.after i got it in bearly, i had NO play w/fork none. still proceded. when i step on clutch there's a serious vibration. lets me shift,it will drive. its just when i step on the pedal. anyone familair w/this?
Hell Hath No Fury Like Mine
Re: 66 hemi 4 speed clutch vibration? [Re: sixpacksteve] #1323369
10/20/12 06:16 PM
10/20/12 06:16 PM
Usa
Smhemi Offline
Smhemi  Offline
Usa
Are you using the stock hemi flywheel and bellhousing
?If you are you got to use the 66-69 hemi 4 speed throw out bearing which are hard to come by. Passion Performance made one for me.
Re: 66 hemi 4 speed clutch vibration? [Re: Smhemi] #1323370
10/20/12 06:56 PM
10/20/12 06:56 PM
N.Y.
N.Y.
what size is that bearing?
Re: 66 hemi 4 speed clutch vibration? [Re: sixpacksteve] #1323371
10/20/12 11:41 PM
10/20/12 11:41 PM
BC Canada
O
ogopogo Online content
ogopogo  Online Content
O
BC Canada
the throwout bearing itself is easy to come by,the throwout bearing collar seems impossible to find.I got mine from passon as well,he machines a regular hemi 4 speed collar .
Re: 66 hemi 4 speed clutch vibration? [Re: ogopogo] #1323372
10/21/12 08:25 AM
10/21/12 08:25 AM
N.Y.
N.Y.
i have the Original collar, SK Speed sent me the same size bearing and collar,WHAT i don't understand is. WHY there's no room for movement.
i done 4 speed's before and Never encountered this. wrong fork? don' think so. bought new one. same as original. pressure plate maybe?
how could that be. it also has original bell.
Re: 66 hemi 4 speed clutch vibration? [Re: sixpacksteve] #1323373
10/21/12 09:37 AM
10/21/12 09:37 AM
N.Y.
N.Y.
took clutch back out, measured from flywheel to where fork goes all the way back. 4", clutch measures 2 1/2"+ 1 1/2" on bearing. O room. what am i missing?
Re: 66 hemi 4 speed clutch vibration? [Re: sixpacksteve] #1323374
10/21/12 06:43 PM
10/21/12 06:43 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i,m betting pressure plate problem of some kind.. good luck
