Take a look at these spark plugs #1322984
10/19/12 10:37 PM
10/19/12 10:37 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
As i took off my headers i pulled the plugs and they all looked like this one in the photo. The plugs have maybe 1000 miles on them.
What do you think, they have a very hard coating on them almost like cement stuck to them.
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322985
10/19/12 10:41 PM
10/19/12 10:41 PM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
you have a very seareous oil problem. does it smoke all the time?; or just at state up.
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322986
10/19/12 10:44 PM
10/19/12 10:44 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Do you have any other pics, different angles etc?
CrAzYMoPaRGuY
Re: Take a look at these spark plugs [Re: 72sat] #1322987
10/19/12 11:18 PM
10/19/12 11:18 PM
Hummmmn no real smoke at start up and no real bad oil usage. If you stomp on it there will be some out the pipes but not anything terrible.
This is the original engine to the car so it's 43 years old.
Oh and i have been running 100 octane as well as Seafoam gas treatment if that means anything??
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322988
10/19/12 11:24 PM
10/19/12 11:24 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
maybe seafoam is cleaning up pistons and valves and it is sticking to your spark plugs?
Re: Take a look at these spark plugs [Re: d-150] #1322989
10/19/12 11:30 PM
10/19/12 11:30 PM
Interesting observation as in the past on start up the engine always a little upper end ticking for a few minutes untill it warmed up and now that you mention it the ticking is gone.
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322990
10/20/12 12:58 AM
10/20/12 12:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From that pic it sure looks like oil is getting into that cyl. Ron
Re: Take a look at these spark plugs [Re: 383man] #1322991
10/20/12 01:27 AM
10/20/12 01:27 AM
Here's one more that's indicitve of all the rest of the plugs.
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322992
10/20/12 02:30 AM
10/20/12 02:30 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Well at 43 years old the valve seals are either gone / rock hard or
Next get a decent compression gauge and go to town and right down the #s
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Take a look at these spark plugs [Re: bee1971] #1322993
10/20/12 09:29 AM
10/20/12 09:29 AM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
The hard whitish deposits is from the seafoam. Most all gas treatments will do that because of the additives..I would burn the rest of the gas in your tank and clean the plugs. Recheck the plugs again in another 1000 and see if they look better..the black deposits look like its running a bit on the rich side...
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322994
10/20/12 11:19 AM
10/20/12 11:19 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Does that plug look 1/8" too short is that just me!
Put a set of RJ12YC's in and try tha! I'm pretty sure that you have the wrong plugs I think what you are using are for a 1941 ford tractor
Re: Take a look at these spark plugs [Re: Dodgem] #1322995
10/20/12 12:13 PM
10/20/12 12:13 PM
Im using and have been using these Accell #8197 spark plugs that are a better fit when using headers that any others i have tried in the past. The engine starts on ome key turn and runs perfectly. So this coating of crud is what is me. Thought maybe it's the brand fuel i use but i only put in Chevron 91 as that's the best we get out here.
Re: Take a look at these spark plugs [Re: MidPenMopar] #1322996
10/20/12 12:35 PM
10/20/12 12:35 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It sure looks like oil to me most likely coming in from the bottom of the intake gaskets or the valve guides.
Stu if you lived closer we could have the next Moparts party engine rebuild cookout
Gus
64 Plymouth Savoy
Dana 60
Re: Take a look at these spark plugs [Re: fourgearsavoy] #1322997
10/20/12 12:48 PM
10/20/12 12:48 PM
Gus
Gus one of the things i have seen from the day i bought the car is a puddle of oil constantly in the valley of the manifold on the driver's side only though...Any thoughts on that?
Re: Take a look at these spark plugs [Re: fourgearsavoy] #1322998
10/20/12 03:03 PM
10/20/12 03:03 PM
Also here's a shot of inside the header tubes. They look like brand new with no a bit of discoloration in the last 10 years of use.
Does tell anything about the fuel mixture or oil usage problem??
Stu
