Roller pilot bearing install questions??
#1322717
10/19/12 02:36 AM
10/19/12 02:36 AM
Posts: 124 Orlando, FL
capt
Orlando, FL
I had no choice but to go with a roller bearing.I have never instlled one before.I was told to just tap it in and to use locktite when installing it.I was also told that the concave side goes in first,with flat side out.I also saw something about how far the bearing should go on the shaft and if its an issue I might have to sand off the ridge of the shaft.I finally was able to down load picture it shows how far the bearing fits on the shaft,the grease mark shows it fits till the ridge of the shaft.The engine was drilled for the trans but not reamed so and shaft was not cut. I could'nt use the brass bearing.Can anyone tell me the right way to get this done?? Thanks
Re: Roller pilot bearing install questions??
[Re: dogdays]
#1322720
10/21/12 12:45 AM
10/21/12 12:45 AM
Posts: 210 mass,usa
sickhemi
mass,usa
the hole in the crankshaft is probably not drilled deep enough. if it wasn't reamed for the brass pilot bushing. i ran into this on a 383 years ago trans would stop about 3/4 of an inch from the bell housing had to use roller bearing and cut the input shaft down
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
