Mopar 727 Transmission Won't Go!!! #1320449
10/14/12 08:39 PM
10/14/12 08:39 PM
Illinois
MagicMan65 Offline OP
Illinois
Gentleman,
I hope hoping you can help me out with this one. I installed a 727 tranny behind my 383
it has a reverse manual valve body with a 2800 stall. I bought this off my buddy who had it in his 65 alter-wheel base car; trans worked fine when pulled. I put this in to find out I am having troubles.
Here is what I am finding:
1. Trans fluid is clean/full check in neutral at normal operating temperature; trans does have a fresh filter.
2. Before I put the drive shaft in with the car on all 4 jack stands I shifted through the gears to find the tail shaft properly spinning.
3. With the drive shaft in I put it in gear and nothing happens.
4. At this point I raised just the rear of the car in the air and then put it in gear to find the rear wheels spinning.
5. I then again put the car back on the ground to find no wheel movement.
6. I pulled the trans cooler line to find the pump does work as it made a large mess on the shop floor.
What are your guys thoughts with all of this? I am beside myself. Thanks for the help in advance.
Regards,
Tar
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320450
10/14/12 09:25 PM
10/14/12 09:25 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I had this happen on a trans I rebuilt for a guy, put it in and the car would not move, jack it up the tires turn, set it on the ground nothing. Turns out when his rearend was narrowed they cut one axle too short, it had a cone posi, longer axle fixed it. Make sure the driveshaft does not turn with both rear wheels on the ground.
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320451
10/14/12 09:31 PM
10/14/12 09:31 PM
We're waiting for Kunkel to come to
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320452
10/14/12 09:38 PM
10/14/12 09:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Did you at any point run the engine, with the tranny/converter dry?...
Re: Mopar 727 Transmission Won't Go!!! [Re: DAYCLONA] #1320453
10/15/12 08:21 AM
10/15/12 08:21 AM
Illinois
Illinois
Thanks for the replies guys, in reponse:
1. I don't think it could be the rear axle, as I have run the same rear end in a previous setup
2. No I never ran the tranny without fluid it in; upon initial startup I had about 8 quarts in the trans and then adjusted accordingly.
Thanks for the help with this, hoping I can find some resolution.
Regards,
Tar
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320454
10/15/12 08:33 AM
10/15/12 08:33 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Have you checked to make sure that the emergency brake is not dragging on the rear drums? (Does it roll forward/backward in N)
Re: Mopar 727 Transmission Won't Go!!! [Re: YO7_A66] #1320455
10/15/12 10:46 AM
10/15/12 10:46 AM
Illinois
Illinois
The e-brake is dis-engaged; the car does move forward and backwards in neutral, when placed in park I cannot roll anywhere.
Thanks,
Tar
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320456
10/15/12 10:56 AM
10/15/12 10:56 AM
Austin, Texas
65Sat440 Offline
65Sat440  Offline
Austin, Texas
Fluid pressure? What year is the tranny? Are you sure the fresh filter is correct for the year, i.e., are all fluid passages clear? Does it shift firmly when running on jackstands?
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320457
10/15/12 12:23 PM
10/15/12 12:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If this a 65 or earlier transmission and you changed the filter,do you have the correct filter ?
The later filter only has one hole and will block fluid to the pump.
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320458
10/15/12 06:54 PM
10/15/12 06:54 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
No wheel movement in forward and Reverse?
The wheels turning on jackstands means nothing due to the "windmilling" effect of the released clutches. Never check transmission operation on jackstands.
Re: Mopar 727 Transmission Won't Go!!! [Re: John_Kunkel] #1320459
10/15/12 08:59 PM
10/15/12 08:59 PM
Illinois
Illinois
Thanks for the comments guys, yes this is correct I do not have forward or reverse movement when all 4 tires on are on the ground. You can tell the car wants to move forward ever so slightly but doesn't . When I do test the car in the air the wheels don't move slow but actually very fast and as you increase engin rpm so does the rpm of the wheels. So I am not sure if the natural "unwinding" of the bands would generate such velocities. Any other thoughts? Do you think I may have a bad torque converter?
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320460
10/15/12 09:14 PM
10/15/12 09:14 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What year is the trans ?
Did you try to stop the tire from turning , put a 2x between the ground and the tire with the engine at idle if you are afraid to do it with your foot .
Re: Mopar 727 Transmission Won't Go!!! [Re: JohnRR] #1320461
10/15/12 10:29 PM
10/15/12 10:29 PM
Illinois
Illinois
The Trans is a 69' tied to a 68' 383. No I haven't tried to stop the tires yet. You guys have any idea what may be going on here, this is driving me nuts!
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320462
10/16/12 12:05 AM
10/16/12 12:05 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If the driveshaft does not turn when both wheels are on the ground in forward or reverse then,
Low fluid
low hydraulic pressures
oil filter clogged
Valve body malfunction
faulty oil pump
clutches non operational
Not much else anyone can tell you without a pressure check and an air check of the servos and clutches. Since you know you have cooler line pressure then I would suspect the valve body.
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320463
10/16/12 01:10 PM
10/16/12 01:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pump has probably failed; even with the drive tangs broken there can be enough friction between the pump rotor and drive hub to create some pressure but not enough to engage a clutch.
Only way to know for sure is to hook up a gauge to the accumulator test port.
Re: Mopar 727 Transmission Won't Go!!! [Re: John_Kunkel] #1320464
10/16/12 03:21 PM
10/16/12 03:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've even seen some get them to move with broken tangs but not good or far!
Re: Mopar 727 Transmission Won't Go!!! [Re: Dodgem] #1320465
10/16/12 11:36 PM
10/16/12 11:36 PM
Illinois
Illinois
Thanks for the input guys; my question is if you think the pump has failed then why do I have good fluid flow to the trans cooler? How hard is to change out the pump? Can you do it with the trans still in the car? Another question I have is regarding vaccum lines, does the 727 have vaccum lines going to it at all?
Tar
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320466
10/17/12 12:39 AM
10/17/12 12:39 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
No vacuum lines, must pull the engine and converter to change pump in car, so it is easier to pull the trans. You need to check the line pressure for better advice.
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320467
10/17/12 01:11 PM
10/17/12 01:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
See my comment above, "even with the drive tangs broken there can be enough friction between the pump rotor and drive hub to create some pressure but not enough to engage a clutch."
Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320468
10/17/12 01:21 PM
10/17/12 01:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
broken pump tangs may have enough grab to pump some fluid but not build the required pressures??
First thing I would do is make sure the shifter is properly adjusted and is moving the trans mission shift lever into detents. (unhook linkage and shift it by hand you will be able to tell.
Then Check the trans pressures if you can get a gauge.
Then pull the oil pan off and see if the valve body is actually getting shifted gear to gear.
then I would drop the valve body and pull out the accumulator and check it's compression ring.
do an air test to check front and rear clutch apply + the servos
If all is well and filters is lined up right try another valve body of you have one.
At this point you have to pull the transmission to check the pump and many other things that can cause a no go!
