Re: Gated or ratchet shifter better for racing? [Re: Thumperdart] #1320199
10/14/12 05:13 PM
10/14/12 05:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
x2. keep it lubed, works perfectly. best one i ever used.
Re: Gated or ratchet shifter better for racing? [Re: Thumperdart] #1320200
10/14/12 05:56 PM
10/14/12 05:56 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
They either get stuck in park or reverse.
My B&M ratchet shifter has worked flawlessly for 14+ years.........so easy a caveman could shift it.
maybe that's my problem. I 'm not a caveman.
I quit using it years ago out of frustration and it's put up. I had another one years earlier that did the same thing and I gave it away.
Went back to pushbuttons('65 tranny) so it's not an issue now.
Re: Gated or ratchet shifter better for racing? [Re: Thumperdart] #1320201
10/14/12 06:02 PM
10/14/12 06:02 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Caveman...That would be me.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Gated or ratchet shifter better for racing? [Re: Adobedude] #1320202
10/14/12 08:05 PM
10/14/12 08:05 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
B&M Pro Ratchet. as close to a slap stick as you can get
Re: Gated or ratchet shifter better for racing? [Re: sixpackgut] #1320203
10/14/12 08:18 PM
10/14/12 08:18 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
B&M Stealth Pro Ratchet with Pistol Grip for me, never missed a shift. Best shifter I have ever owned.
Re: Gated or ratchet shifter better for racing? [Re: sixpackgut] #1320204
10/14/12 08:34 PM
10/14/12 08:34 PM
I've bought, used and race both types of most of the popular brands out there. I now have a used Winters shifters in my Duster and another used Fairbanks for the new race car, 1965 Dart. T/A uses the same basic shifter as the Winters/Fairbanks except they are rear exit cables and sideways mounted shift linkage, it is a H.D. garbage truck shifter to start with(1/4 inch Morse cable, not a 1/8 inch diameter cable :thumb) and then made into a kit for race cars The T/A units are front mounted cable exit and hook onto the shift arms like all the other front shifted cable shifters. I have shifted it into 2nd gear when I left my hand on the shifter handle when I hit the throttle in first gear, probally several other racers on here have also Once you learn to stiffen your arm up enough to take a 1G+ launch your golden I've done the same thing on a ratchet shifter also I have never shifted mine into high gear from first I know of several other Mopar racers that would have bought the new Winters/Fairbanks shifters according to them but they where to much money for them at that time One of them has since replaced his B&M (maybe it was a Hurst) ratchet shifter because he wore it out, in 13YRS+ racing The H.D. truck units don't wear out Bottom line is it is up to you to decide which one you want Good luck
Re: Gated or ratchet shifter better for racing? [Re: Cab_Burge] #1320205
10/14/12 08:50 PM
10/14/12 08:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Just watch Pass Time every week and you'll have your answer. It's amazing how many automatic cars miss a shift on that show. I always run the B&M Pro Ratchet, impossible to ever miss a shift.
Re: Gated or ratchet shifter better for racing? [Re: Cab_Burge] #1320206
10/14/12 08:52 PM
10/14/12 08:52 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I want this ever so badly for the racecar.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Gated or ratchet shifter better for racing? [Re: sunroofgtx] #1320207
10/15/12 02:25 AM
10/15/12 02:25 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
B&M Pro Ratchet here as well! I love it. You cant miss a shift!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Gated or ratchet shifter better for racing? [Re: 52savoy] #1320208
10/15/12 10:44 AM
10/15/12 10:44 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Hurst Pro-matic ratchet shifter has worked flawlessly for 14+ years.........so easy a caveman could shift it.
Re: Gated or ratchet shifter better for racing? [Re: mshred] #1320209
10/15/12 10:50 AM
10/15/12 10:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I like my B&M Quicksilver. Ratchet Action!
Coming soon!!!!
