Re: Camshaft Trouble.
[Re: 1976Fury]
#1319755
10/13/12 04:38 PM
10/13/12 04:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Oil in the cyls would be a major concern right now... and all you did was line up the dots doesnt say antyhing... I have had cams made wrong(factory ones) and they would hit the pistons if you lined up the dots... I will assume you checked to see if the dist is 180* out
[Re: 1976Fury]
#1319757
10/13/12 05:27 PM
10/13/12 05:27 PM
MR_P_BODY
yup it should have went like a dream. So pull the cam and see whats up with it?
I wouldnt YET... have you done any checking yet to what it might be.... do you have the equipment to check the degree on the cam
[Re: 1976Fury]
#1319759
10/13/12 05:49 PM
10/13/12 05:49 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
they face each other, and that is #6 firing
when they are both at 12 oclock that is #1 firing.
This can confuse most people until they get the hang of it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: 1976Fury]
#1319762
10/13/12 07:02 PM
10/13/12 07:02 PM
Rapid340
oberlin, Ohio
check/clean your plugs and check wires ( firing order) and then try moving distributor and check with timing light.
probably nothing wrong with the cam. If it starts it may run rough until all lifters pump up.
[Re: 1976Fury]
#1319763
10/13/12 07:03 PM
10/13/12 07:03 PM
MR_P_BODY
Do you have a compression gauge or a buddy have one.. do a quick compression check.... have you checked the timing yet
[Re: RobX4406]
#1319766
10/13/12 09:29 PM
10/13/12 09:29 PM
Posts: 20,175 Park Forest, IL
slantzilla
Park Forest, IL
Are you 100% sure it's oil on the plugs and not gas?
I have a couple Mopar Performance chain sets that have the timing marks 2 teeth off. Degreeing the cam is cheap insurance.
If you put a cap and wires on are the wires on the cap in the correct direction?
[Re: Cab_Burge]
#1319768
10/14/12 09:00 PM
10/14/12 09:00 PM
Posts: 70 Wyoming, USA
1976Fury
Wyoming, USA
Broke down and just tore into the motor. I think i found my bone head problem. I put my timing mark on the harmonic balance on zero. Then pulled timin cover off. The marks on the two gears were straight up on both. the distributor cap was burnt up. I dont quite know if anything else is burnt up yet.
