Camshaft Trouble. #1319754
10/13/12 04:22 PM
10/13/12 04:22 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Just installed a new cam in my 360sb and now no start. It will sputter and backfire. I lined up my timing marks correctly on the timing gear. Also im getting oil in my cylinders. Pulled the plugs and everyone had a coat of oil on it. Any insite woiuld be amazing
Re: Camshaft Trouble. [Re: 1976Fury] #1319755
10/13/12 04:38 PM
10/13/12 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Oil in the cyls would be a major concern right now...
and all you did was line up the dots doesnt say antyhing...
I have had cams made wrong(factory ones) and they would
hit the pistons if you lined up the dots... I will
assume you checked to see if the dist is 180* out
Re: Camshaft Trouble. [Re: MR_P_BODY] #1319756
10/13/12 04:43 PM
10/13/12 04:43 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
yup it should have went like a dream. So pull the cam and see whats up with it?
Re: Camshaft Trouble. [Re: 1976Fury] #1319757
10/13/12 05:27 PM
10/13/12 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt YET... have you done any checking yet to
what it might be.... do you have the equipment to
check the degree on the cam
Re: Camshaft Trouble. [Re: MR_P_BODY] #1319758
10/13/12 05:45 PM
10/13/12 05:45 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
I do not. Ive been doing some reading and do the timing marks on the cam and crank gears face eachother or point straight up?
Re: Camshaft Trouble. [Re: 1976Fury] #1319759
10/13/12 05:49 PM
10/13/12 05:49 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
they face each other, and that is #6 firing
when they are both at 12 oclock that is #1 firing.
This can confuse most people until they get the hang of it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Camshaft Trouble. [Re: Rapid340] #1319760
10/13/12 06:45 PM
10/13/12 06:45 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
that is very helpful i was lost there. Its still accting way out of time. i just dont want to pull the motor apart again
Re: Camshaft Trouble. [Re: 1976Fury] #1319761
10/13/12 06:54 PM
10/13/12 06:54 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
its a comp cam. did i waste my time and cash?
Re: Camshaft Trouble. [Re: 1976Fury] #1319762
10/13/12 07:02 PM
10/13/12 07:02 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
check/clean your plugs and check wires ( firing order) and then try moving distributor and check with timing light.
probably nothing wrong with the cam. If it starts it may run rough until all lifters pump up.
Re: Camshaft Trouble. [Re: 1976Fury] #1319763
10/13/12 07:03 PM
10/13/12 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have a compression gauge or a buddy have one..
do a quick compression check.... have you checked the
timing yet
Re: Camshaft Trouble. [Re: MR_P_BODY] #1319764
10/13/12 08:32 PM
10/13/12 08:32 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Are you using adjustable rockers/pushrods? What cam- hydraulic or solid? Might have the valves set wrong and valves arent closing..
Re: Camshaft Trouble. [Re: Hot 340] #1319765
10/13/12 08:53 PM
10/13/12 08:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
A flat cam isn't generally going to oil up the cylinders and NOT all of them.
I'd be looking at the intake manifold gaskets as a culrpit. You have the locator pins on the valley rails and using silicone, not the cork?
Re: Camshaft Trouble. [Re: RobX4406] #1319766
10/13/12 09:29 PM
10/13/12 09:29 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Are you 100% sure it's oil on the plugs and not gas?
I have a couple Mopar Performance chain sets that have the timing marks 2 teeth off. Degreeing the cam is cheap insurance.
If you put a cap and wires on are the wires on the cap in the correct direction?
Re: Camshaft Trouble. [Re: 1976Fury] #1319767
10/13/12 11:33 PM
10/13/12 11:33 PM
Pull the #1 spark plug and put your finger or thumb over the hole and have someone bup the starter around a little at a time until the #1 piston starts to blow your finger(or thumb) off the spark plug hole. Stop there and look at the timing mark on the timing tab and the balancer, barely bump the starter to get the balancer timing mark to be close to 10 to 20 degrees before top dead center. Pull the distributor cap off and see whre the rotor is pointing, if it is not pointing close to just before the number #1 spark plug wire fix it by reindexing the distributor or oil pump drive, or both if that is waht it takes BTW, did you replace the timing chain and gear swith a three keyway set? If so which sets of dots did you use? The ones next to the crankshaft itself or the ones on the outer edge of the crank gear
Re: Camshaft Trouble. [Re: Cab_Burge] #1319768
10/14/12 09:00 PM
10/14/12 09:00 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Broke down and just tore into the motor. I think i found my bone head problem. I put my timing mark on the harmonic balance on zero. Then pulled timin cover off. The marks on the two gears were straight up on both. the distributor cap was burnt up. I dont quite know if anything else is burnt up yet.
Re: Camshaft Trouble. [Re: 1976Fury] #1319769
10/14/12 09:06 PM
10/14/12 09:06 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
oil prob was a terrible seal on the valve covers. When i pulled the rest of the plugs they were dry. Kinda freaked out there for a bit sorry fellas.
