Re: Been thinking about 383 man Ron Nies Sr.`s car.........
[Re: JACK1440]
#1317219
10/08/12 01:24 PM
10/08/12 01:24 PM
Thumperdart
State of confusion
That`s about what I was thinking maybe more as long as it`s tuned and a wide-band "before and after" comparison would be interesting........... And a quick "BS" on loosing torque and driveability.................
[Re: Thumperdart]
#1317220
10/08/12 02:02 PM
10/08/12 02:02 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
It sure runs good for a mild motor in a heavy car.
[Re: Thumperdart]
#1317222
10/08/12 02:19 PM
10/08/12 02:19 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
i'd try a bigger carb first. The easiest way to handicap a dual plane (vs a single plane) is to run the same size carb; a dual plane wants at least another 100 cfm to make it a fair comparison. The 440-2D is no slouch, especially ported. The lower plenum picks up about 30cfm, out of the box it's about 30 down to the upper. Ported like mine the 2D will flow ~360 cfm. I offered Ron a virgin 337 single plane and my pro-systems 1000hp 4150 to try. But I'd like him to try just the carb on the dial plane first. I haven't swapped the 337 because I can't convince myself it's worth it on my 517, at least until I go to the 4 speed.
[Re: 64Post]
#1317224
10/08/12 03:47 PM
10/08/12 03:47 PM
Thumperdart
State of confusion
I`d just like to see a back to back "real world" test on a known good car and would be willing to bet the open manifold w/a 1050 dommy would improve at least .02 or more................ New tires definately..........
[Re: Thumperdart]
#1317226
10/08/12 04:36 PM
10/08/12 04:36 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks for thinking of me as I really appreciate the offers. First I do need new slicks which I will have to get over the winter as I just dont have any spare cash right now. The other problem is my hood clearance issue. I dont want to change the scoop as I just dont care for the modern taller version of the Maxie scoop. No offense meant to anyone who uses them but I like the more original look. That said I would love to do what Streetwize said and try the Mopar 337 single plane as from what he said it should fit under my hood and I hear it is a very good single plane intake. And by all means I would love to try a bigger carb. I am very pleased the car has run 10.70's but I do think it has a bit more in it and I will get around to trying the different intakes and carbs but it may take me some time as my back and knees slow me down alot as does a slight lack of cash right now. But you all really have me thinking. I plan to hope I can try some changes next spring and summer. I mean believe me I am a gearhead and as with all of us its never fast enough. So it may take me some time but I most definetly plan to see how much faster it will go with a few changes and good tuning. Since I think the 337 will fit under my hood I would love to try it with a bigger carb. I can try a carb first on the Indy dual plane and then go from there. You can see the height of the Indy dual plane here as I have a 1" spacer under it and it just clears my scoop as I have about a 1/2" to 3/4" room between the carb stud and bottom of the scoop. But I will have to wait until next spring like March or April I hope. As I have to live within my means right now and with Xmas coming sooner then we know it and xmass is going to be tuff enough this year. Hopefully I can get my funds straightened out over the winter and get my case with workers comp straight as I still am paying for my pain meds out of my pocket and I am still trying to get medical insurance. Since I am only 56 it seems you have to be 65 or on disability for 2 years before I can get Medicare. But I am working with a Health insurance through Social Services that I think is free for me on disability with just a co pay for perscriptions. Dont mean to bore you guys with my problems but once I get these few things ironed out I may even be able to save some money. Believe me it hurts to see all these new best et's get posted and me knowing I never even got to the track this year. But my plans are new slicks over the winter and then hope by April I can go to the track and try a few things. I replaced my little Holley red pump with the Firecore 140 pump but I have not been back to the track to see if it helps as the last time out I thought I was not pumping enough fuel with the red pump as I dropped 3 mph when I shifted at 6000. So I shifted the next run at 5700 and picked the 3 mph right back up to almost 125. So I hope the larger fuel pump takes care of that problem. After I ran 10.76 @ 124.49 at Cecil with a 1.50 sixty I went to Capital 2 weeks later and the first run was 11.02 @ 121. So the next pass I short shifted at 5700 and ran 10.83 @ 124.56 but with a 1.54 sixty as I had trouble hooking good that day. But then after looking at the holes in the slicks or lack of them I knew it was time for new slicks. So I hope the new fuel pump and slicks help as well as a single plane and larger carb when I get to try them. I really appreciate all the idea's and help offered. I should know by April next year when I can get to the track and try a few things. Ron
[Re: MIKES_DUSTER]
#1317232
10/08/12 05:13 PM
10/08/12 05:13 PM
Thumperdart
State of confusion
I still say 1050 dommy flange EVEN w/an adapter but then hood clearance goes further out the window.........
[Re: MIKES_DUSTER]
#1317234
10/08/12 05:22 PM
10/08/12 05:22 PM
383man
Balt. Md
Any one have a nice 950 he could borrow?? Ron,you ever run it down the track with no air cleaner??
I dont use that little air cleaner as I put that on for an indoor car show because the old one was actually hitting the hood. Then I got the larger chrome one thats a drop base. I have never uncapped it either but it is a 3" X-pipe system with Ultra-Flows out to the rear bumber and I believe it flows pretty good. Ron
[Re: MIKES_DUSTER]
#1317235
10/08/12 05:23 PM
10/08/12 05:23 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
He could use my 950 HP, but I understand the secondary venturies on the 850 are a little bigger than the 950.
I think the next step up in appreciable gains from the 850 would be the 1050.
[Re: Thumperdart]
#1317236
10/08/12 05:43 PM
10/08/12 05:43 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'm always all for going faster..... but Let's not forget that Ron is running an 8-3/4" under that substantial slab of B-Body iron. I believe he has a Detroit locker in it, which is a big upgrade, but last I heard, the axles and housing are stock fare. If I were Ron, before I spent $$$ on going faster, I'd invest in a back brace and a set of good axles for his 8-3/4.... OR start building a Dana. DAHIK.....
