Need help: Dodge neon A/C question
#1314137
10/02/12 12:20 AM
10/02/12 12:20 AM
Posts: 1,630 North Central Florida
eightlitermopar
2001 Dodge Neon SE Automatic (100 K miles)
The air conditioning will blows warm air, but works intermittently for a few minutes at a time. The fans come on when the a/c switch is turned on. I’m not hearing the compressor engage though, which confuses me since it blows cold air sometimes.
When cold air is blowing, the return line under the hood is cold to the touch. When it only blows warm air, both lines are warm (being under the hood)
Anyway, I’m not very experienced with AC units. Is this a normal breakdown occurrence with Neon’s a/c systems?
I have a Haynes manual, but before I start digging in I thought I would ask on this forum. Perhaps there is something simple I could be overlooking. Loose connections/ bad sensors?
I don’t want to start throwing parts or R134A (expen$ive!) at it if it doesn’t need it.
Anyway, your thoughts?
Eightlitermopar
Mopar or no car
Re: Need help: Dodge neon A/C question
[Re: Magnumguy]
#1314141
10/04/12 09:55 PM
10/04/12 09:55 PM
eightlitermopar
Thanks for the input.
We tried charging it today, but nothing happened. I assume the system is fully charged.
On my 2001, the low pressure cut off switch is on the firewall right in front of the passenger side. If it is "loose" (I haven't checked yet) does this mean the connector is loose or it has come unscrewed or what?
Is the high cut off switch right on the compressor?
Also, if I need to change these switches, do I need to release the system pressure first, or can they be replaced with a full system?
My dad's chevy truck does not require the system pressure to be released for the sensors to be changed, this is why I ask....
eightlitermopar
Mopar or no car
