PRW Roller Rockers any good #1313226
09/30/12 01:49 PM
09/30/12 01:49 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Got a 440 and its getting cold out so that's about the time to upgrade. Im looking to upgrade my rockers and i really want a nice set of the Harland Sharp Roller Rockers but that's just not gonna fall into my budget. So i came across PRW Roller rockers. Anyone running them. Got anything good or bad to say about them. Or any other subjection.
Also i understand the Ratio B.S a little. Anyways should i Run The 1.5, 1.6 or 1.7 Rockers. 1.7 Is probably out of the question. I pretty much have a 440 Six Pack Minus the Six pack. So Six Pack Rods Crank Pistons. Also im Running the Mopar Purple shaft cam. Witch i Believe is .509/.509lift 292/292Dur.. Correct me if im wrong please.
Anyways Some suggestions would be nice.
Jordan
Re: PRW Roller Rockers any good [Re: jordan91] #1313227
09/30/12 02:59 PM
09/30/12 02:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Lots of different 'purple' shafts.
Why do you want to run roller rockers. You will gain little if any performance. Especially on the street. You may gain a little rocker ratio correction and therefore a slight gain but for the price rockers + push rods and running on the street if it ain't broke don't fix it. I might add that roller rockers are not made for a lot of street usage. They do come have a tendency with usage to come apart and put little needles through the engine.
Re: PRW Roller Rockers any good [Re: MoparforLife] #1313228
09/30/12 04:07 PM
09/30/12 04:07 PM
PA
W
w7smallblock Offline
W
PA
I wouldn't use the aluminum ones but the stainless ones for what you are doing they would be fine, I have a set on my smallblock with a .512 lift hydraulic roller and no complaints. Ryan J has them on his bigblock street car with hydraulic roller cam and over 10,000 miles last I talked to him.
Re: PRW Roller Rockers any good [Re: w7smallblock] #1313229
09/30/12 05:27 PM
09/30/12 05:27 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Thanks, Yes them are the ones im looking at. The Stainless Steel PRW ones. I was thinking them would be my best bet for the steet ability. Are them what you Run The S-S PRW rockers?
Re: PRW Roller Rockers any good [Re: MoparforLife] #1313230
09/30/12 05:30 PM
09/30/12 05:30 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Yes ive herd most of that information. And the Aint broke dont fix it part i already have to pull them off so im think i may as well go ahead. And the Set i was looking at im sure i can utilize the pushrods i alread have. If not im sure i can upgrade there to.
Jordan
Re: PRW Roller Rockers any good [Re: jordan91] #1313231
09/30/12 10:20 PM
09/30/12 10:20 PM
Amherst,NY
challengermike Offline
Amherst,NY
I have a set of stainless ones on my engine.I have just run into a problem with the adjusters loosening up. The nut would fall off and the adjuster would spin all the way up and then it would bust the cup on the adjuster.I set mine up with ball/ball pushrods. I had to order a set of harlan sharp adjusters ($170) to fix the problem. Also when i installed them on the engine i had to grind them so the rocker body wouldnt hit the valve stem instead of the roller. Other than these issues im happy with them. Im only running a cam with 540/555 lift though.
Re: PRW Roller Rockers any good [Re: jordan91] #1313232
10/01/12 12:46 AM
10/01/12 12:46 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have a set of PRW roller rockers on Da Beast’s 496 wedge. I have over 350 passes on them with no problems. I check the valves every 100 passes. I usually only find one or two that need to be adjusted and those will only be off a couple thousands. Good rockers for the price.
Re: PRW Roller Rockers any good [Re: Dabee] #1313233
10/01/12 01:19 AM
10/01/12 01:19 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why do you want to put roller rockers on an engine that has a cam that clearly doesn't need them? You won't gain anything measurable performance-wise. Flushing money down the toilet IMO. Now if you were to ditch the .509 and go with a solid cam or a roller, then you would have a use for those adjustable rockers. Spend the money on something that will get you some actual hp returns for your investment.
Re: PRW Roller Rockers any good [Re: DaytonaTurbo] #1313234
10/01/12 01:09 PM
10/01/12 01:09 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Ahh i see. I dont build motors so i don't know to much. Im not trying to sound like an idiot on here either just looking for some good opinions like yours. so thanks for the input its much appreciated!!
Also during Break in period a coupple of the rockers had excessive ware on the bottom side were it rotates on the shaft. so i already have to replace them. I forgot to put that in
Re: PRW Roller Rockers any good [Re: Dabee] #1313235
10/01/12 01:11 PM
10/01/12 01:11 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Do you use the stainless steel Prw Or the Aluminum Rockers, Thanks
Re: PRW Roller Rockers any good [Re: jordan91] #1313236
10/01/12 01:58 PM
10/01/12 01:58 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Harlan-Sharp does offer a lower cost bushed rocker that is at least 200.00 cheaper than the originals.Better choice.
Leave the gun.......take the Cannoli's....Mike
Re: PRW Roller Rockers any good [Re: jordan91] #1313237
10/01/12 03:20 PM
10/01/12 03:20 PM
Manitoba, Canada
Manitoba, Canada
Then in that case I would just pick up some used stockers for cheap out of the moparts for sale section and swap out the worn ones. Most guys running the .509 cam are running stock rockers and I still believe that spending money on adjustables is a waste unless you're going to upgrade to a cam that requires them. I have a set of crane roller rockers waiting to go on my engine, but I also have a solid cam that will be going in.
Re: PRW Roller Rockers any good [Re: DaytonaTurbo] #1313238
10/01/12 04:48 PM
10/01/12 04:48 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I had a .509 in a 440 in my 69 Sport Satellite several years ago, and switching from the stock rockers to a set of 1.5 Crane Gold rollers picked me up from 12.40s to 12.20s and gained a little over 1.5mph. Keep in mind stock rocker arm ratio is somewhere around 1.42.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: PRW Roller Rockers any good [Re: DconD100] #1313239
10/01/12 07:15 PM
10/01/12 07:15 PM
dogdays Offline
dogdays  Offline
That's exactly why aftermarket rockers are better. You get a more exact ratio.
Now to the question of ratio, I'd suggest you look at your heads and stock pushrods. Increasing the ratio moves the pushrod toward the cylinder. You may have to clearance your heads. I'd stick with the 1.6 at a maximum.
R.
Re: PRW Roller Rockers any good [Re: DconD100] #1313240
10/01/12 08:59 PM
10/01/12 08:59 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.......Keep in mind stock rocker arm ratio is somewhere around 1.42.
I always wonder if those that make this statement have actually measured this with repeated results, heard it from someone else, or read it in a magazine? The number seems to get lower and lower over time as well.
The ones that I have measured were nowhere near this low.
Re: PRW Roller Rockers any good [Re: dogdays] #1313241
10/02/12 01:46 AM
10/02/12 01:46 AM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Hmm well Im sure your all right lets just not bicker. I guess it just a choice of personal preference and opinions. And we know when it comes to motors everyone is gonna have there own opinion. Ill just have to make up my mind when it comes time to buy them when im ready
Re: PRW Roller Rockers any good [Re: jordan91] #1313242
10/02/12 01:57 AM
10/02/12 01:57 AM
Manitoba, Canada
Manitoba, Canada
Nobody's bickering, just throwing the info out there. Other guys can read it too and gain from it. Your wallet will be lighter and your engine will run the same, but if you've decided you want them that's all that really matters. I personally would be apprehensive about running the PRW rockers over a better known brand like crane or similar. Haven't heard anything bad about the PRW rockers but plenty of stories about the el cheapo china rockers letting go sending bearings and adjuster bits through your engine.
Re: PRW Roller Rockers any good [Re: DaytonaTurbo] #1313243
10/02/12 03:55 AM
10/02/12 03:55 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Even when we bicker there's info for everybody
It's the Moparts way sometimes
It's not officially bickering until there's a double or triple quote followed by a interesting rebuttal
Any bushed rocker requires a hardened shaft with banana grooves & hardened or chroe moly pushrods
Re: PRW Roller Rockers any good [Re: DaytonaTurbo] #1313244
10/02/12 07:53 AM
10/02/12 07:53 AM
Upper Midwest
Upper Midwest
I had a set of Cranes on my 360 for over a season and went back to the HD stamped because I didn't gain a thing and some one else wanted the "WOW I got roller rockers" factor.
Re: PRW Roller Rockers any good [Re: BulletBob] #1313245
10/02/12 07:58 AM
10/02/12 07:58 AM
PA
W
W
PA
I didn't measure the rocker ratio but I did check lift at the valve with a solid lifter and zero lash. The new factory replacement rockers lift at the valve was .480 and with the 1.6 PRW stainless the lift was .512 this is with a .344 lobe.
