plastic straw in cylinder
#1312327
09/29/12 10:44 AM
09/29/12 10:44 AM
Posts: 571 central PA
mopartial
central PA
I was spraying lube into small block cylinder for winterization and the little plastic straw fell off and into cylinder. Gonna be tough to fish out. Im thinking it would vaporize and get blown out of there on re-starting.
Anyone have thoughts on this?
If it aint broke, dont break it.
Re: plastic straw in cylinder
[Re: mopartial]
#1312328
09/29/12 12:41 PM
09/29/12 12:41 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't start it!!! It will not vaporize instantly!!! It could hang a valve open a little bit and bend it when the piston comes up!!!
[Re: 71sat440]
#1312330
09/29/12 01:27 PM
09/29/12 01:27 PM
mopartial
central PA
Ugh! I should have quit after fogging thru carb. This is in a bilge and hard to reach which is why it happened in the first place...this is not gonna be fun.
Anyway thanks for replies...
[Re: mopartial]
#1312331
09/29/12 02:59 PM
09/29/12 02:59 PM
RapidRobert
I had that happen once & I ran it no problem. could duct tape the end of your shop vac down to a piece of vac line of the appropriate diameter & see if you could fish it out
[Re: CrazyD]
#1312333
09/29/12 04:19 PM
09/29/12 04:19 PM
Posts: 12,005 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You may get another straw just like it and see if brake clean or lacquer thinner or something like that will melt it. If so, you can then spray some of it in the cylinder to at least partially melt it and then run it to do away with the rest of it.
Master, again and still
[Re: bobs66440]
#1312335
09/29/12 04:32 PM
09/29/12 04:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Oh for pete's sake.
I once dropped a check ball from my carb down the plenum.
I said nuts to it and ran the 318, no problems and it's been over 10 years now.
[Re: Supercuda]
#1312336
09/29/12 05:37 PM
09/29/12 05:37 PM
Posts: 583 NJ
rth
NJ
[Re: rth]
#1312337
09/29/12 06:09 PM
09/29/12 06:09 PM
Posts: 1,819 South Bend
John Brown
South Bend
The magic fingers gripper tool might do the job.
[Re: bonefish]
#1312339
09/29/12 11:44 PM
09/29/12 11:44 PM
Posts: 2,497 God's Country Maryland
GODSCOUNTRY340
That little straw is not going to hurt the engine. Even if it does get hung up in a valve if your valve springs aren't strong enough to crush that little tube of plastic you've got other problems. Start that sucker and let it melt away!
[Re: Supercuda]
#1312340
09/30/12 08:14 AM
09/30/12 08:14 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Oh for pete's sake.
You're making that up, aren't you.
[Re: scratchnfotraction]
#1312342
09/30/12 11:26 AM
09/30/12 11:26 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I've had a few valve seals make the journey to the bottom of the pan...No harm done. [image] [/image]
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
