Re: Ammeter Reading Question
[Re: Supercuda]
#1312324
09/30/12 09:00 PM
09/30/12 09:00 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Basic is this, he has additional loads wired directly to the battery. I do not care if your alternator puts out a billion amps at idle, it will show a + on the ammeter wired like that.
yeap, definitelly, that's because the power will go through the ammeter, without NEED for that if you hook it correctly to alt stud. But need a GOOD alt to source it from there and not require power from batt, getting the ammeter in play reading discharge, no matter if alt is still working, but not enough
