70 RR Positive battery cable....? #1311205
09/26/12 09:40 PM
09/26/12 09:40 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
YO lists it at > $200... RockAuto is < $20... what do you get from RockAuto ( no pic...)??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Positive battery cable....? [Re: JMCFAN] #1311206
09/27/12 11:04 AM
09/27/12 11:04 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
You won't be getting anything that resembles an accurate reproduction for $20, but if you do please let us know .
Re: 70 RR Positive battery cable....? [Re: JMCFAN] #1311207
09/27/12 11:36 AM
09/27/12 11:36 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
$200 ?
I need to raise my prices
ps. the rockauto cable is nothing more than a single lead wire with ends on it. the wires that go to the relay are NOT on it
Re: 70 RR Positive battery cable....? [Re: gtx6970] #1311208
09/27/12 11:56 AM
09/27/12 11:56 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I knew if I posted I would find another source!
$219 to be exact... in my catalog..
Re: 70 RR Positive battery cable....? [Re: JMCFAN] #1311209
09/27/12 12:00 PM
09/27/12 12:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
pm sent
Re: 70 RR Positive battery cable....? [Re: gtx6970] #1311210
09/27/12 12:32 PM
09/27/12 12:32 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I went with year one in the end, for my wiring harnesses and battery cables. Not cheap by any means, but sure look nice ! ha ha ha . . . only issue with the B Body harness (M&H manufactures), is that they INCLUDE the hidden headlight wiring in the harness, even though the label states, B Body, NOT including Charger !!! No biggy, either unwrap and take out, then retape, or clip the ends off and retape.
Mark
