727 not upshifting...update 10/03/12
#1310612
09/25/12 09:42 PM
09/25/12 09:42 PM
Posts: 138 Mcgregor, Ia
493RT
Mcgregor, Ia
Went out for a maiden test drive and the transmission does not want to upshift into 2nd or drive. Has reverse and 1st, but nothing in between. I tried adjusting the kick down linkage in a couple of different settings , but still no change. Transmission was rebuilt last year by a local shop, that I've had do work in the past. Fluid level checks good when up to temp.
Re: 727 not upshifting...
[Re: 493RT]
#1310613
09/26/12 01:58 AM
09/26/12 01:58 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Might have a stuck governor that is what i would look at first. If it were me i would probably replace it with one that had a higher rpm shift point to match my camshaft power band if i had to go in there.Get the 727 hand book very easy to read and very helpful .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#1310614
09/26/12 08:35 AM
09/26/12 08:35 AM
Posts: 582 PA
BTTG
PA
if so may be able to fix without pulling anything apart???? https://board.moparts.org/ubbthreads/show...&PHPSESSID=not sure, but checking governor pressures before may save some time <2psi in D 0 mph...increase about 1 psi/1mph while in D
[Re: 493RT]
#1310615
09/26/12 05:58 PM
09/26/12 05:58 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First, disconnect the TP linkage at the transmission lever and pull the lever full forward. Take it for a drive...if it still won't upshift the problem is in the governor.
[Re: 493RT]
#1310619
10/04/12 03:51 PM
10/04/12 03:51 PM
John_Kunkel
Rio Linda, CA
Before you pulled the tail did you try disconnecting the TP linkage? Did you check the governor pressure?
[Re: 493RT]
#1310621
10/04/12 07:42 PM
10/04/12 07:42 PM
John_Kunkel
Rio Linda, CA
The position of the components is different when there is pressure in the system....with no pressure the weight is subject to the laws of gravity.
Without a pressure check to make sure the governor is actually the problem all you can do is make sure the valve and weight are free to move.
The problem could just as well be a stuck valve in the valve body.
