VENT GLASS TAPE #1310424
09/25/12 03:00 PM
09/25/12 03:00 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I know some people glue their vent glass in the channel with 3M black adhesive, or Permatex adhesive. Does any one sell the original tape that holds the glass in the channel, if so where can you get it and what is it called, or do most people use the adhesive? Thanks
Re: VENT GLASS TAPE [Re: JohnH] #1310425
09/25/12 07:29 PM
09/25/12 07:29 PM
Indiana
P
Pentastar440 Offline
P
Indiana
I got the window tape from a local glass shop in a roll. They told me that I could use adhesive , but said if adhesive is used it would be very hard to get the glass out if it ever needed to come out. I wouldn't think on a vent wing that the glass would ever need to come out though.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: VENT GLASS TAPE [Re: Pentastar440] #1310426
09/25/12 09:20 PM
09/25/12 09:20 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Depending on the year Bill Petrow has the correct cut vinyl tape And the correct molded plastic pieces:
http://special-ts.tripod.com/
special_t_bill@yahoo.com
103 N. Wheeling Rd
Prospect Hts IL 60070
Phone: 847-255-5494
Fax: 847-466-5991
Re: VENT GLASS TAPE [Re: TooMany62s] #1310427
09/26/12 04:56 PM
09/26/12 04:56 PM
Utah
E
Eagleone1983 Offline
E
Utah
It's called glass setting tape and depending on the thickness you need, I may have some you could have. To figure out what thickness you need just measure the vent channel the glass sits in and the glass thickness and subtract, then divide by two.
