383/484 stroker engine.. #1308108
09/21/12 09:53 AM
09/21/12 09:53 AM
queensland australia
V
val440 Offline OP
val440  Offline OP
V
any pro,s and con,s to these combos....any info would be greatly welcomed...what sort of power can these strokers make reliably....
Re: 383/484 stroker engine.. [Re: val440] #1308109
09/21/12 08:03 PM
09/21/12 08:03 PM
dogdays Offline
dogdays  Offline
As much as the heads and redline will allow.
R.
Re: 383/484 stroker engine.. [Re: val440] #1308110
09/21/12 08:07 PM
09/21/12 08:07 PM
dogdays Offline
dogdays  Offline
Like, 750 hp is 1.55 lb/cubic inch and will require heads with a max flow around 360 cfm.
R.
Re: 383/484 stroker engine.. [Re: dogdays] #1308111
09/21/12 11:07 PM
09/21/12 11:07 PM
V
val440 Offline OP
val440  Offline OP
V
i have a set of stage 111 cnc ported victor snr heads,m1 high rise manifold with a 1050 dominator....these obviously make good power in the right combo....something around a 650ish solid roller in the 280s-290s @50 for a cam...would it be a reliable combo....anymore input would be greatly appreciated....have looked on different sights but have not found much info...thanks guys...
