A-body S&W 8 point cage kit pics #1307054
09/19/12 08:57 PM
09/19/12 08:57 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey everyone,
Im going to be ordering a pre fabbed cage for my 71 scamp from S&W in the 8 point offerring. I wanted to see pics of those installed in members cars to see what fitment is like in terms of my front kick panels (They are speaker kickpanels), the cross bar, and the rear downbars (I know there is a pro street bar going through the speaker holes and the standard going through the rear seat area- would like to see where in the trunk these attach to).
Also curious which kit you guys are using- the mild steel EWS, the DOM tubing, or the Moly stuff? I want something affordable, preferably that I can mig myself at home, but not overly heavy (I know the moly is lighter, but by how much really??). I need this to pass tech for running 10's, so I just want to make sure I order the right material for the bars as well
Thanks!
Matthew
Re: A-body S&W 8 point cage kit pics [Re: mshred] #1307055
09/19/12 09:13 PM
09/19/12 09:13 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have the same kit in my scamp and I did the street bars to save rear seat. Fit was good had some minor tweekin.I have the cromo.
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307056
09/19/12 09:17 PM
09/19/12 09:17 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
any pics? chromoly require tig welding right?
Re: A-body S&W 8 point cage kit pics [Re: mshred] #1307057
09/19/12 09:25 PM
09/19/12 09:25 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
pic
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307058
09/19/12 09:26 PM
09/19/12 09:26 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
2
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307059
09/19/12 09:27 PM
09/19/12 09:27 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
3
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307060
09/19/12 09:28 PM
09/19/12 09:28 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307061
09/19/12 09:29 PM
09/19/12 09:29 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307062
09/19/12 09:29 PM
09/19/12 09:29 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307063
09/19/12 10:05 PM
09/19/12 10:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
pics look good man! I like where the front bars come down, looks like I can make them work with my speaker setup. Im curious to see how the rear down bars look in the trunk with that pro street bar setup.
Did you tig the setup in? or you had someone do it?
still trying to decide which material to go with
Re: A-body S&W 8 point cage kit pics [Re: mshred] #1307064
09/20/12 05:35 AM
09/20/12 05:35 AM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
Yes.
Re: A-body S&W 8 point cage kit pics [Re: Max Wedge Savoy] #1307065
09/20/12 06:18 AM
09/20/12 06:18 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
All tig except floor plates. I had to increase the bend in rear bars to clear the filler pipe.
Re: A-body S&W 8 point cage kit pics [Re: Scamp408] #1307066
09/20/12 06:54 AM
09/20/12 06:54 AM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
S&W mild steel. Cert to 8.50 though I'll never go that fast.
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: A-body S&W 8 point cage kit pics [Re: Butch] #1307067
09/20/12 10:33 AM
09/20/12 10:33 AM
michigan woods
imfixinmopars426 Offline
michigan woods
anybody consider these cages? chrome moly for 699.00...free shipping....anyone use these?...mike http://www.ebay.com/itm/Roll-Bars-and-Ca...=item3a6cafef11
Re: A-body S&W 8 point cage kit pics [Re: imfixinmopars426] #1307068
09/20/12 04:26 PM
09/20/12 04:26 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
Why don't you at least price one through your local chassis shop. I just had a 6 pt MS roll bar installed by Comp Chassis here in Phoenix for $700.00 complete in my 67 Cuda fast back. The rear down bars follow the roof line to the trunk. I like the look. I'll post pics later if your want.
Re: A-body S&W 8 point cage kit pics [Re: 6pak2go] #1307069
09/20/12 05:18 PM
09/20/12 05:18 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
As for my local chassis shop, they want 250 a point, and only do moly...so an 8 point cage is 2000 dollars....way out of my price range
Re: A-body S&W 8 point cage kit pics [Re: mshred] #1307070
09/20/12 07:37 PM
09/20/12 07:37 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have an S&W cage in my car. Installed by S&W (not cheap, but done right) I'll post some different pics of it that havn't been posted.
Re: A-body S&W 8 point cage kit pics [Re: 70HemiGTX] #1307071
09/20/12 07:39 PM
09/20/12 07:39 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The halo bar and down legs. Lots of room around the kick-panels. You have to slide them in from the rear though. Past the down leg.
Re: A-body S&W 8 point cage kit pics [Re: 70HemiGTX] #1307072
09/20/12 07:40 PM
09/20/12 07:40 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The trunk
Re: A-body S&W 8 point cage kit pics [Re: 70HemiGTX] #1307073
09/20/12 07:41 PM
09/20/12 07:41 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The lower down legs.
