Hard starting when hot lapping --- opinions please #1305653
09/17/12 01:45 PM
09/17/12 01:45 PM
Aurora, Oh.
max_maniac Offline OP
Aurora, Oh.
Have an issue getting my car started when hot lapping and this starts even on the 2nd run. Once the car gets hot it seems to drag the battery down or is it the starter?
Set up on 63 Dodge - Brand new Red Top, MSD 6AL, Mopar mini starter from a Dakota, Summit elec water pump, Be Cool fan on rad, Aeromotive 2000 fuel pump and a tach.
So where to start looking first when it comes to electrical I'm lost. First instinct is to get a better starter then the stock Mopar mini...
Thanks for any opinions and/or advice.
Russ
Re: Hard starting when hot lapping --- opinions please [Re: max_maniac] #1305654
09/17/12 01:51 PM
09/17/12 01:51 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
Is your timing locked out?
Re: Hard starting when hot lapping --- opinions please [Re: vttm] #1305655
09/17/12 01:54 PM
09/17/12 01:54 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm thinking its a lack of battery power, not a starter or engine issue.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Hard starting when hot lapping --- opinions please [Re: max_maniac] #1305656
09/17/12 02:05 PM
09/17/12 02:05 PM
Check all your grounds
Re: Hard starting when hot lapping --- opinions please [Re: Cab_Burge] #1305657
09/17/12 02:26 PM
09/17/12 02:26 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i have my timing set at 25 deg on start up.
Re: Hard starting when hot lapping --- opinions please [Re: ro23car] #1305658
09/17/12 03:17 PM
09/17/12 03:17 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
It's the starter - it's a wee bit cranky like the old & retired owner
Re: Hard starting when hot lapping --- opinions please [Re: DoubleD] #1305659
09/17/12 04:36 PM
09/17/12 04:36 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
How big of wire do you have for ground???If too small it will crank slow hot.
JAKES AUTOMOTIVE
Re: Hard starting when hot lapping --- opinions please [Re: max_maniac] #1305660
09/17/12 04:37 PM
09/17/12 04:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
are u using an alternator? it wasn't mentioned. if u are, check the output terminal at the alt, should be atleast 14-14.5.
Re: Hard starting when hot lapping --- opinions please [Re: rickraw] #1305661
09/17/12 04:50 PM
09/17/12 04:50 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
You can check to see if you have a wiring issue first as its the easiest issue to eliminate....
On mine, I check all the large wire connections for resistance with an Ohm meter...Especially, the on off switch. Found those go bad and create lots of resistance over time or voltage drop, and crimp connections for big wires are no good over time either. Mine are all soldered...
That's where I would start...
Re: Hard starting when hot lapping --- opinions please [Re: Dragula] #1305662
09/17/12 05:03 PM
09/17/12 05:03 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Starter.
There are heat shields available (mostly for Chevy) but that's a band aid.
Replace it.
Re: Hard starting when hot lapping --- opinions please [Re: AAR-B4] #1305663
09/17/12 05:12 PM
09/17/12 05:12 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Put a heat blanket on the starter, esp. if its close to the headers. a sheetmetal shield is even better if there's room. My oem starter was acting up then eventually would just stay on. There was a week where I would start it, jump out, pull the negative battery cable to stop the starter spinning, and real quick hook it back up before the motor died.
When I went to a mini it would heat soak and start very slowly if I drove then parked and let the heat soak in. Later I had jacked my timing up to 22 initial with a new (hot rod) motor and put the battery in the trunk. I had to run a thick ground all the way to the starter mounting lug to get good cold starts. Hot starts with all the initial timing work WAY better with a separate button to crank the starter, then turn the key on once it spins good.
That's what worked for me!
Good luck
radar
Re: Hard starting when hot lapping --- opinions please [Re: radar] #1305664
09/17/12 05:24 PM
09/17/12 05:24 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
most hot start problems are engine timing, try turning off ignition or pull coil wire when cranking, see if it makes a differance
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Hard starting when hot lapping --- opinions please [Re: max_maniac] #1305665
09/17/12 05:38 PM
09/17/12 05:38 PM
Az
Crizila Offline
Crizila  Offline
Az
Since the battery is new, you can eliminate it. That leaves the wiring, connections, and starter. After visually checking the wiring and connections for corrosion, loosness, etc, you will need to do a voltage drop test on the starting system wiring. Over all starting system should have less than .6 voltage drop with .1 or less for each connection. With the ignition system disconnected, you will need to crank the engine about 5 seconds for each connection you are testing to let the reading line out. If your system passes the voltage drop tests, you starter is the problem. It just don't have enough balls to start the motor hot - especially when it is also hot. You can do some things to help it - as mentioned, but the problem is still the starter.
Fastest 300
Re: Hard starting when hot lapping --- opinions please [Re: Crizila] #1305666
09/17/12 05:44 PM
09/17/12 05:44 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Just an FYI,
I went to the parts store 3 times to get a good Optima red top. First two were very weak. Third one was my last try at using one,then it worked great for years. I would start by getting the battery and starter tested.
Keith
Re: Hard starting when hot lapping --- opinions please [Re: Dunnuck Racing] #1305667
09/17/12 05:49 PM
09/17/12 05:49 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Its hard to beat a good 16 volt battery.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Hard starting when hot lapping --- opinions please [Re: Dunnuck Racing] #1305668
09/17/12 05:57 PM
09/17/12 05:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Just an FYI,
Keith
Well, there is always an exception to the rule, and most people don't have a load tester in their garage, but most have a volt meter. Your starter might load test just fine ( no heat ) for what it is, but it just doesn't have enough nuts to crank your motor - hot. You said it came out of a Dakota? Assume it is used and was cranking much less of a motor than you are presently using it on??.
Fastest 300
Re: Hard starting when hot lapping --- opinions please [Re: Crizila] #1305669
09/17/12 06:09 PM
09/17/12 06:09 PM
Northern Indiana
Northern Indiana
Just an FYI,
Keith
I agree! Most of the parts stores will test them for free
Re: Hard starting when hot lapping --- opinions please [Re: max_maniac] #1305670
09/17/12 06:54 PM
09/17/12 06:54 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
We tried everything, wrapped the starter, new starter, load tests, amp draws, everything!
This guy fixed it
http://www.madelectrical.com/
Call him and get the kit. Makes it real easy.
The Dart now cranks hard and fast, hot or cold.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
