Re: 1995 360 Mechanical Fuel Pump Suggestion
[Re: scratchnfotraction]
#1305178
10/10/12 11:44 PM
10/10/12 11:44 PM
Posts: 352 McHenry, Illinois
RAUPLEMINZE454
McHenry, Illinois
do you have a part# for that cam?
I have a mopar catalog I can look the specs up.
yes you can see the ecentric in place thru the FP hole.
4 things I would want to know.
1)is it a long or short nose roller cam?
2) is it drilled to oil thru head to the shaft rockers?
3) are the roller lifters oil thru style with hollow PRs?
(they can use solid PRs also but good to know what you have.)
*** 4) did they drill the 95 block to oil thru the heads to the shaft mount rockers??
magnum blocks are not drilled for LA style oiling when running pre-mag heads.
Scratch,
As far as the oiling, I checked that last July:
https://board.moparts.org/ubbthreads/show...rue#Post6707768
You were actually helping me back then also. Here is the thread where I checked the oiling with by priming:
https://board.moparts.org/ubbthreads/show...rue#Post6810115
You also helped when he snapped that bolt off in the trans case.
Anyways I will have to try and find out if it is a long nose or short nose roller cam. I will email the builder and get back to you guys.
I appreciate the help, this has been going on for a long time. Its my brothers car and he has had it for about 9 years, he also just became a father. So with the busy schedule of being a new parent and then all of my stuff I have going on, we are wayyyy behind schedule.
Thanks to all, I appreciate the help
-Brian
#1305183
10/14/12 11:19 PM
10/14/12 11:19 PM
RAUPLEMINZE454
McHenry, Illinois
i think bolt a fuel pump on and good to go.
that is INDEED the fuel pump ecentric.
if the arm on the FP wants to hold you up on the bolt aline ment,rotate the engine and roll the ecentric to the far side and pressure of the pump stroke.
Sweet!!!!!! So I am assuming that the eccentric is lobed? How else would it move the pump arm?
[Re: RAUPLEMINZE454]
#1305186
10/16/12 04:30 PM
10/16/12 04:30 PM
Posts: 15,487 Florida
scratchnfotraction
Thanks to everyone for the help guys!!! Especially Scratch once again for always being there to answer about stuff. I have a Carter Super Mechanical M6902 on order and can know hopefully move forward a few more steps.
