Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305178
10/10/12 11:44 PM
10/10/12 11:44 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
do you have a part# for that cam?
I have a mopar catalog I can look the specs up.
yes you can see the ecentric in place thru the FP hole.
4 things I would want to know.
1)is it a long or short nose roller cam?
2) is it drilled to oil thru head to the shaft rockers?
3) are the roller lifters oil thru style with hollow PRs?
(they can use solid PRs also but good to know what you have.)
*** 4) did they drill the 95 block to oil thru the heads to the shaft mount rockers??
magnum blocks are not drilled for LA style oiling when running pre-mag heads.
Scratch,
As far as the oiling, I checked that last July:
https://board.moparts.org/ubbthreads/show...rue#Post6707768
You were actually helping me back then also. Here is the thread where I checked the oiling with by priming:
https://board.moparts.org/ubbthreads/show...rue#Post6810115
You also helped when he snapped that bolt off in the trans case.
Anyways I will have to try and find out if it is a long nose or short nose roller cam. I will email the builder and get back to you guys.
I appreciate the help, this has been going on for a long time. Its my brothers car and he has had it for about 9 years, he also just became a father. So with the busy schedule of being a new parent and then all of my stuff I have going on, we are wayyyy behind schedule.
Thanks to all, I appreciate the help
-Brian
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305179
10/10/12 11:46 PM
10/10/12 11:46 PM
McHenry, Illinois
McHenry, Illinois
What does the ecentric actually look like when I look in the fuel pump hole? What am I looking for?
Thanks,
Brian
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305180
10/11/12 02:01 PM
10/11/12 02:01 PM
McHenry, Illinois
McHenry, Illinois
He just got back to me and stated that it should be a long nose.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305181
10/14/12 07:46 PM
10/14/12 07:46 PM
McHenry, Illinois
McHenry, Illinois
I was able to pull off the block off plate today and this is what I am working with:
What do you guys think?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305182
10/14/12 08:19 PM
10/14/12 08:19 PM
scratchnfotraction Offline
i think bolt a fuel pump on and good to go.
that is INDEED the fuel pump ecentric.
if the arm on the FP wants to hold you up on the bolt aline ment,rotate the engine and roll the ecentric to the far side and pressure of the pump stroke.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305183
10/14/12 11:19 PM
10/14/12 11:19 PM
McHenry, Illinois
McHenry, Illinois
Sweet!!!!!! So I am assuming that the eccentric is lobed? How else would it move the pump arm?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305184
10/15/12 09:30 AM
10/15/12 09:30 AM
it has a offset from the center bolt so as it spins it pushes down on the fp arm then let it come back up for the pump action.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305185
10/16/12 12:02 PM
10/16/12 12:02 PM
McHenry, Illinois
McHenry, Illinois
Thanks to everyone for the help guys!!! Especially Scratch once again for always being there to answer about stuff. I have a Carter Super Mechanical M6902 on order and can now hopefully move forward a few more steps.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305186
10/16/12 04:30 PM
10/16/12 04:30 PM
Thanks to everyone for the help guys!!! Especially Scratch once again for always being there to answer about stuff. I have a Carter Super Mechanical M6902 on order and can know hopefully move forward a few more steps.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305187
10/16/12 05:41 PM
10/16/12 05:41 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I was told that the MP camshafts all had long snouts for an eccentric. I also was told all MP crate engines had an eccentric on them.
