Is there such a thing as manual disc brakes? #1304703
09/16/12 08:57 AM
09/16/12 08:57 AM
mississauga, ontario, canada
P
patbee383 Offline OP
P
I converted from drums to disc during resto but brakes are really bad, just wondering if i missed a step? maybe i need the booster? Using original style master cylender changed proportioning valve. I've, bled brakes many times...
1970 Dodge Superbee 2008 Dodge Ram 2500 HEAVY DUTY 2011 Dodge Caravan 2002 Honda Accord?
Re: Is there such a thing as manual disc brakes? [Re: patbee383] #1304704
09/16/12 09:11 AM
09/16/12 09:11 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Yes. The drum mc will work. A disc mc holds more fluid because as the pads wear the caliper fills. No big deal just check your level once in a while. Also when you squeeze the calipers open to put in new pads have a turkey baster ready to suck some extra fluid out of the mc so it doesnt overflow.
Try cleaning the floor real good or put down cardboard to find a possible small dripping leak. You said it's not a new mc right? So it couldnt need to be bench bled first?
Re: Is there such a thing as manual disc brakes? [Re: patbee383] #1304705
09/16/12 09:13 AM
09/16/12 09:13 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I run manual discs on my car with no issues. What exactly is the problem? I used a M/C spec'd for a 1976 Plymouth Valiant with manual disc brakes. I think it was 1 11/32" bore.
Re: Is there such a thing as manual disc brakes? [Re: Jeremiah] #1304706
09/16/12 09:53 AM
09/16/12 09:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
need more info! what parts did you use? are these 1970s factory disc brakes? what master cylinder did you use?
yes, you can get manual disc brakes and have them work well.
check this forum for a LOT of brake information from sizing your master, to figuring out your line pressures:
https://board.moparts.org/ubbthreads/postlist.php?Cat=0&Board=Corners
**Photobucket sucks**
Re: Is there such a thing as manual disc brakes? [Re: 70Cuda383] #1304707
09/16/12 11:18 AM
09/16/12 11:18 AM
Athens, Greece
Pyper70 Online content
Pyper70  Online Content
Athens, Greece
You sure you have the right master? The piston changes between the years for power/manual operation. Maybe you have the 7/8" piston and you need the 1 1/8". I stole the disc's off of a 75 A-body along with the prop block and suspension. I loved my manual disc brakes. One less thing in the engine bay of a 70 Dart. Slant 6. Also make sure your brake lines don't have a bubble where the banjo is, might have fluid escaping or sucking air in with every pump. I use the stainless braid on brake lines.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Is there such a thing as manual disc brakes? [Re: Pyper70] #1304708
09/16/12 11:20 AM
09/16/12 11:20 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The best brakes I ever had were manual discs that were factory on 67 Dart GTS's.
JB Rhinehart, Realist
A-Body's RULE!
Re: Is there such a thing as manual disc brakes? [Re: patbee383] #1304709
09/16/12 11:51 AM
09/16/12 11:51 AM
cbusters Offline
cbusters  Offline
I did a Master Power conversion and had horrible brakes. Bled them 4 times and still no pedal. Called them and found that the calipers were not mounted high enough to bleed all the air. Rotated them up another bolt location and now they are solid as a rock. Fantastic system. Even without a booster they are easy to use.
Re: Is there such a thing as manual disc brakes? [Re: Rhinodart] #1304710
09/16/12 11:53 AM
09/16/12 11:53 AM
P
P
Awsome advice guys! At this point i cant get at it, but will have it up on a hoist this week, im sure he put in a factory replacement(or aftermarket but looks like orig.)The master was bench bled, all new lines, gravity bled (whatever that means) and bled again. but the brakes really suck (seem to be getting worse and going to floor now) so maybe there is a leak or air still in system.
I will keep you posted when i get to it this week (i hope)
Re: Is there such a thing as manual disc brakes? [Re: patbee383] #1304711
09/16/12 12:07 PM
09/16/12 12:07 PM
Take off the lines from the M/C & bleed it out seperately then hookup the 2 lines & bleed RR LR RF LF. When doing the front discs what can help is to pump the pedal several times fast to agitate the air/fluid mixture then have a helper time it just right and open the caliper bleeder as you're pushing down on the 4th stroke. If there is still a problem take off the lines again & get some brass inverted flare caps from the "Edelman" fittings cabinet at your parts house (they're cheap & you will reuse them) and plug the M/C. If the M/C is good and bled out the pedal will be rock hard with virtually no travel. With that confirmed hookup the forward port to the rear brake line and bleed them out. With it high and tight hookup the line to the front discs & work on them.
Re: Is there such a thing as manual disc brakes? [Re: Jeremiah] #1304712
09/16/12 12:18 PM
09/16/12 12:18 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Uhhh, with a master cylinder bore of that size, you'd need legs the size of Lou Ferrigno to stop a tricycle!
Maybe 1 1/32?
Using a drum/drum master cylinder isn't advised anyway. The volume isn't right, the bore size isn't right. As stated before, more info is needed to provide any help.
Re: Is there such a thing as manual disc brakes? [Re: Kern Dog] #1304713
09/16/12 12:22 PM
09/16/12 12:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My 74 dart had factory manual disc brakes. That was the best braking mopar I ever owned. More than enough stopping power and provided really nice road feel when on the brakes.
Re: Is there such a thing as manual disc brakes? [Re: patbee383] #1304714
09/16/12 01:28 PM
09/16/12 01:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You need to post some info on the car and parts used,.....the drum/drum master has to go though, use a correct disc/drum master, bore size could be determined if we knew the type/size of calipers used, rear drum specs, etc, etc
